electric fuel pump conversion
Old Jun 24, 2016 | 12:01 PM
Matt Newby's Avatar
Matt Newby
how do all, I was wondering if it is possible, due to budget, to perform the electric fuel pump conversion in steps. by that I mean could I remove the mechanical pump and install the electric pump on the frame, but retain the stock filter housing and regulator? I would use high pressure hose and run from the stock pump supply line on top of the engine to the fuel bowl inlet and then use high pressure to run to a three way fitting, and a bit more hose to join the fitting to the stock lines running to the head. later as budget allow I will replace the filter assembly and regulator and then the lines to the heads.
thanks guys
Old Jun 24, 2016 | 12:03 PM
Rikster-7700's Avatar
Rikster-7700
thanks guys
I think you need the next forum down, all our generation of trucks have an electrical fuel pump?
Old Jun 24, 2016 | 12:06 PM
Matt Newby's Avatar
Matt Newby
opps seems I did put this in the wrong place...thanks though.
Matt Newby
Jul 22, 2016 05:39 AM
lunkerbuster
Apr 26, 2010 12:12 PM
1966Tbird
Sep 15, 2009 05:05 PM
Kenneth Brown
Oct 29, 2008 03:14 PM
colton
Aug 30, 2006 04:52 PM
