Fuel pump
Old Aug 30, 2006 | 03:12 PM
colton's Avatar
colton
Fuel pump
I think my fuel pump is starting to go out. With other vehicles I have changed old mechanical pumps for electric pumps wired to a hidden switch. It just sounds like changing out the mechanical pump is a lot of work. Has any one found a way to use a electric pump to re-place the mechanical one?
Old Aug 30, 2006 | 04:45 PM
1997F-350's Avatar
1997F-350
uh yes. you can do it. the superduties have em. bdp sells a kit for the obs trucks. or you could piece it together yourself.
Old Aug 30, 2006 | 04:49 PM
barebackjake's Avatar
barebackjake
yep theres alot of us runnin electric fuel systems now, the way the regulator is setup though it aint cheap to go electric. by the time you setup filtration, regulator, and pump and the lines your in about $800 atleast if you do it all yourself.
im running a mallory 110FI pump, mallory regulator, dahl 150 filter, ran 5/8" to the motor and 1/2" back, its definately a project also. set up a pressure switch offthe oil pressure to control the pump.
if you have a stock injectored rig the mechanical fuel pump works great and lasts a long time.
Old Aug 30, 2006 | 04:52 PM
1997F-350's Avatar
1997F-350
halfway down the page or so
Redneckrucker16
Feb 28, 2014 02:49 PM
Aaron M Sholley
24
Jan 8, 2014 07:47 AM
whipple_ryan
Jul 28, 2009 08:44 AM
rmalottwtes30
Jul 18, 2005 08:04 PM
original67
Feb 20, 2004 06:17 PM
