Fuel Pump Upgrade??????????
Old Sep 14, 2009 | 08:40 PM
1966Tbird's Avatar
1966Tbird
anyone know how to upgrade the fuel pump? can i just use an msd booster pump with the stock fuel pump and be alright or do i need to replace the stock fuel pump with a dummy hose and run an external electric pump like a holley black pump or equivilent (i don't like the holley style pumps) this is for a carbed application, i have the stock fuel system with a braided -6an line coming off the fuel filter to a bypass fuel pressure regulator then to my carb and a -6an return line off the regulator back to the gas tank
i really like the aeromotive fuel pumps and i'm thinking about finding one and running it external to the tank but i don't know if i can pull fuel through my stock intank fuel pump or not
Old Sep 14, 2009 | 09:28 PM
1966Tbird's Avatar
1966Tbird
is a 460 fuel pump the same as a 5.0 fuel pump?
Old Sep 15, 2009 | 06:42 AM
subford's Avatar
subford
Yes it is.
Puts out about 100 PSI into a blocked head.
It will also pump 125 LPH @ 42 PSI.
Old Sep 15, 2009 | 08:01 AM
1966Tbird's Avatar
1966Tbird
how much horsepower does that support? do you think it would support 520+ horsepower? i think i will be making around 540 with nitrous but havn't ran the desktop dyno
Old Sep 15, 2009 | 09:22 AM
Conanski's Avatar
Conanski
I don't think it will support 500+ hp, it's only marginally larger than the small block pumps which are around 80gph. There are a few guys around here that are sucessfully running the booster pumps on supercharged motors.. I believe Blurry94 is one.. maybe one of these guys will comment.
Old Sep 15, 2009 | 05:05 PM
1966Tbird's Avatar
1966Tbird
yeah i want to do my fuel system overkill so i don't run lean at high rpms on juice, hope someone else gives me a tip
