Towing with my 15 Ecoboost Screw
#61
I agree with the majority of your post, but not your conclusion. As a former professional driver I've logged hundreds of thousands of miles pulling trailers between 10,000-62,000 lbs with an 18,000 lb road tractor. Nearly a million of these vehicles are on the road today, and they do just fine. Professional drivers understand how their vehicles handle, and the good ones drive accordingly.
It can be done, but conventional trailers are much more finnicky about the setup than fifth wheels because of how the pivot point is behind the rear axle. You can adjust tongue weight as needed by changing the load of the trailer, and yaw inertia would be adjusted accordingly assuming the trailer frame remains intact.
Also, it's a rule that I'm going to break because the new trailer we're looking at will likely be around 6000lbs loaded up. BUT, it's very compact for that weight and much of the heavy stuff is located at the axles so it should be fine. Hopefully.
#62
We picked up the new TT today, and it tracked just fine driving up 101 (& 85) from Morgan Hill to Saratoga. I briefly took it to 70 MPH, but it was just fine. My wife was certain that a vehicle pulling a trailer is limited to 55 on that stretch, so I compromised at 60. No problems. Then came up highway 9, which is a windy mountain road for about 7 miles. Everything tracked beautifully, but my mileage went from ~~ 19 MPG to ~~ 11 MPG. Even went to 10 for a bit coming up the mountain (climbing from 500' ASL to 2600' ASL).
This is with 3.31 gears. I didn't put the tranny into tow mode until we started climbing the mountain.
Bottom line: no problems.
#63
#64
AFAIK, they did a standard installation. I didn't watch every minute, but it looked pretty standard to me.
The truck with the trailer & hitch installed has approximately the same stance as with nothing attached (back end slightly high relative to the front end).
This is a Fastway e2 WD hitch. No chains. It uses a couple of large L brackets instead. The torsion bars rest on top of the L brackets, and have a flat interface between the torsion bars and L bracket. This is an anti-sway hitch to begin with.
#65
#66
We heard nothing from it on our trip home; it was very quiet.
#67
https://www.google.com/url?sa=t&rct=...EsclsVT-V7Hx4A
#68
#69
Actually the Reese uses the friction pads and according to them they reduce sway 10 times better than the metal to metal design.
#70
#73
Mark250
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
21
08-17-2019 08:49 PM
71LTD390
05-14-2007 10:15 PM
