Another Sway Thread
Old Jun 6, 2019 | 08:38 AM
Mark250's Avatar
Mark250
Another Sway Thread
I'm using a Reese Pro Series sway control, no wdh with this setup. 70 psi in the rears, 60 in the front, trailer tires aired up to specs. I have plenty of tongue weight. I really have to fight crosswinds and trucks passing. Pulls nice with no crosswind. Would a wdh make any difference? I have lots of towing experience but never used a wdh. This is a 350 and camper is about 5k loaded. Came from a 2002 350 SRW, I suppose the sway was about the same with that one.
Old Jun 6, 2019 | 09:42 AM
HRTKD's Avatar
HRTKD
I've never pulled a trailer that had just sway control. I've either had nothing or I had full WDH w/Sway Control. So I can't speak for how well sway-only works.
Your trailer looks to be nose down. I would bring it up a couple inches.
I have a toy hauler. If anything is going to catch the wind, it's my toy hauler. I've used two different brands of WDH with it and both have worked well. Blue Ox and Andersen. Given the truck you have, the Andersen would be ideal.
Old Jun 6, 2019 | 02:15 PM
1dryfly's Avatar
1dryfly
A trip to the Cat scales would be a good idea. Load it up like you travel.
Old Jun 6, 2019 | 06:11 PM
Desert Don's Avatar
Desert Don
Both of these guys are correct.
Get the front of the trailer up.
Get to the scales and KNOW what you have.
Old Jun 7, 2019 | 05:53 AM
Mark250's Avatar
Mark250
I actually have it nose down for a reason-I plan to drop the suspension an inch and that should level it out some. I don't like they way they build these so high anymore.
Old Jun 7, 2019 | 08:43 AM
seventyseven250's Avatar
seventyseven250
With that small of a trailer, are you seeing the trailer sway behind you, or is it transferring to the truck and moving the truck too?
A WDH would help, even if it doesn't have specific "anti-sway" components because it transfers weight to BOTH the trailer axles and the truck steering axle. It should be a pretty forgiving setup with a heavy truck and light trailer.
Old Jun 7, 2019 | 08:52 AM
Mark250's Avatar
Mark250
Actually it's not trailer sway so much but the whole unit gets pushed around like a solid block. I have no concerns about tongue weight, the tongue is plenty heavy with a full tank of water up front and heavy items stowed to the front.
Old Jun 7, 2019 | 09:36 AM
seventyseven250
If everything is moving sideways as a solid block, that's about as good as you can do. Simply being heavier will reduce that somewhat, or reducing side-area by having a low profile trailer.
Old Jun 17, 2019 | 09:35 AM
The John's Avatar
The John
Do you tow with water in your fresh water tank? I know for my Timber Ridge it tows better with at least a quarter tank of water.
Old Jun 24, 2019 | 05:58 PM
NWnative's Avatar
NWnative
The nose of the trailer is low. If you plan to lower it, you will still need to raise the ball height some. Getting pushed around by wind and Semi's passing is par for the course when towing a big lightweight box out back. A good WDH with Sway will help. It's common physics...move some of that weight off the the back axle of the truck and send a little to the front and I am sure you will notice a significant improvement. Your manual will indicate how to properly set it up if you go that route.
Old Jun 26, 2019 | 12:06 AM
glockholiday's Avatar
glockholiday
I love my Equal-i-zer brand WDH. No chains, no clamp friction bars, no reversing restrictions. https://www.equalizerhitch.com/store/hitches
Old Jul 1, 2019 | 02:18 PM
wrvond's Avatar
wrvond
All the Passports I have pulled have towed remarkably well in my opinion. I've certainly experienced no perceptible sway in reaction to wind or passing semi's. It may be that the nose low position of your camper is causing your problem because your two axles are not carrying the weight equally. This can result in unusual behavior. Once you flip the axles and get the unit level, you'll likely see a marked improvement in handling.
A WDH can reduce the sway tendencies of a camper by increasing the weight that is on the axles, resulting in a more "planted" trailer. However, I would want a comprehensive scale session to know what I was dealing with before throwing money at it.
Old Jul 3, 2019 | 12:28 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
I tend to agree with folks above:
- Raise nose of trailer or lower trailer at axles, an inch seems about right if you add a WDH.
- Go to a WDH to get some more weight on the truck's front axle
Remember: tongue weight (from a bumper-pull) doesn't just add weight to the rear axle, it also subtracts weight from the front axle. This will make the steering react differently than empty, and also differently than same combination with a WDH putting a few hundred pounds back on the front axle. Dropping the rear down through whatever means changes the geometry between the front axle and the pavement. Raising the front does it more.
Old Aug 1, 2019 | 09:08 PM
Jakerichards1's Avatar
Jakerichards1
Reese straightline
Wdh reese straight line. I vote for. Love mine.
Centering sway control. No other does that I think.
my truck and trailer moves as a whole unit.
Truck traffic bow wave will never go away but it can be minimized.
Clamp type froction sway comtrol should should be avoided. It just does not work well enough.
Old Aug 3, 2019 | 04:23 PM
PlanoRob's Avatar
PlanoRob
My Jayco 28bhs bucks the trend by pulling better with the nose down a little and some water in the fresh tank. Tried for a whole year to make it pull straight while perfectly level and it was horrible no matter what.
