Engine stuck in high idle
Old Jun 21, 2016 | 10:11 AM
goose_ss4's Avatar
goose_ss4
I have a 2002 f250 auto 7.3
I am having a strange problem.
When driving the engine idles at 900 or 800, which I assume is high idle.
If I shift out of drive to neutral and back to drive it goes away, and idle how it should. 650 rum
Icp, ipr, ebps, ebps tube, regulated return, fuel mods good pressure, and new trans range sensor
What could be causing this, and what should be my next trouble shooting step? I am so lost on this thing.
Please and thank you
Old Jun 21, 2016 | 10:12 AM
goose_ss4's Avatar
goose_ss4
Oh I also did an injector buzz test and they all sounded good
Old Jun 21, 2016 | 10:21 AM
clem1226's Avatar
clem1226
My first "next" step would be to monitor entgine oil temp and outside air temp, make sure they are reporting something that makes sense.
You also may want to take a look at the throttle position sensor....
Old Jun 21, 2016 | 10:47 AM
goose_ss4's Avatar
goose_ss4
Throttle position sensor reading 0 when stuck in high idle
Intake air temp within 10° of ambient outside temp. Probably closer to 5°
Oil temp is 203 when it's 100°f down here in alabama
Old Jun 21, 2016 | 11:52 AM
goose_ss4's Avatar
goose_ss4
I am going to scan for codes again after work.
Last time I got an high ebps reading code, so I put on a new sensor last night to take care of that.
The only other thing was AIH circuit low or something due to the delete mod.
Old Jun 21, 2016 | 04:33 PM
goose_ss4's Avatar
goose_ss4
Scan codes and only found was AIH circuit low because of my delete mod.
One thing I did notice is that my Map and my Ebps are not reading the same with KOEO???
Map was at 13.1
And ebps was at 14.9
Koen was:
Map 13.1 still
Ebps was 15.1
Could this be it!
Old Jun 21, 2016 | 09:49 PM
pirschwagon's Avatar
pirschwagon
First question is: Do your Brake lights work? And, your Parking Brake Light on the dash. Either should disable the fast idle.
Second, try disconnecting both the EVB Tube Sensor and EBPV Plug.
Third, check your MAP hose for a loose connection or hole.
Lastly, monitor Sensor Voltage rather than values.
BARO: 5 Volt Reference Circuit, @ 4.6 volts / 14.7 psig at sea level, decreasing as altitude increases.
EBP: 5.0 volts Reference Circuit, 0.8-1.0 vdc / 14.7 psig
EOT: 5 Volt Reference Circuit, 4.37 vdc @ 32°F, 1.37volts @ 176°F, 0.96volts @ 205°F.
IAT: 5 Volt Reference Circuit, 3.897 vdc @ 32°F, 3.09 @ 68°F, 1.72 @ 122°F.
Old Jun 28, 2016 | 01:59 PM
goose_ss4's Avatar
goose_ss4
I just notice a cab light is burned out and will check tailights tonight. My dash lights just started acting up at night flash on and off. Think it's a bad ground
cajun1965
1997 - 2003 F150
Mar 5, 2010 04:23 AM
muddman77
Jan 27, 2010 09:30 PM
sideshow
Feb 19, 2008 06:58 PM
highboy390fe
20
Feb 12, 2007 05:32 PM
bad ass diesel
Jan 30, 2007 06:11 PM
