Restabbing distributor
Old Jun 20, 2016 | 01:13 PM
TheSterling's Avatar
TheSterling
So I pulled the dizzy to restab it in another position for tuning, now I can't get it to reseat on top of the oil pump shaft because the shaft isn't directly in the middle. What are my options here? I was thinking of using a magnet to pull it out and using black rtv to stick the shaft to the bottom of the dizzy so I could get it to seat. Any other recommendations or ideas?
Old Jun 20, 2016 | 02:00 PM
JD Q's Avatar
JD Q
I believe that there is a thread in this site for this, somewhere.
I believe that globing some multipurpose grease between the shaft and block will hold the shaft in place long enough to stab the dizzy.
Old Jun 20, 2016 | 02:16 PM
Tedster9's Avatar
Tedster9
Aren't oil pumps usually stuffed with vaseline prior to startup? So that would be a safe choice I'm thinkin'. Grease would work fine too.
Old Jun 20, 2016 | 03:19 PM
mountain dewd's Avatar
mountain dewd
I just wiggled, twisted, rotated, and swore at mine until it dropped right into place.
Old Jun 20, 2016 | 04:07 PM
HIO Silver's Avatar
HIO Silver
Hopefully your truck is parked on level surface... but the oil pump drive shouldn't be wandering/teetering anyways..... if the dizzy isn't seating on the shaft, by hand rotate the engine a touch.
How to Install a New Distributor - Car Craft Magazine
Old Jun 20, 2016 | 04:48 PM
hivoltj's Avatar
hivoltj
Ya or jack up the front or rear end depending on which way it needs to go. U shouldn't be able to pull the shaft out; it should have a retaining washer on it
Old Jun 20, 2016 | 07:14 PM
mountain dewd
Unless it was like mine, where the PO removed that washer, and the drive shaft falls into the pan...
Old Jun 20, 2016 | 07:20 PM
gemutlich's Avatar
gemutlich
Dang man the more you talk about what the PO did to your truck the more I don't think he shoulda even had a tricycle let alone that truck!
Old Jun 20, 2016 | 07:22 PM
mountain dewd
You have NO idea how bad it was man. Scary. A tricycle would be too fast/complicated/valuable for them!
Old May 16, 2022 | 06:20 AM
nighthawking's Avatar
nighthawking
I think I know that guy.
Old May 16, 2022 | 07:12 PM
5851a's Avatar
5851a
Make sure it's in park or neutral with brake set. If you have the gear indexed, take a screwdriver and jump from battery positive to S terminal on solenoid while pushing down on distributor cap with medium pressure. It should drop in within a revolution. You may have to back up crank to check. If you end up with the rotor centered over the 1 of the 12127,, timing point on 10 degree btc you should be ready vacuum can pointed straight forward. Check timing afterwards. Should be within a degree or two. Chisel mark on block should line up at distibutor base or very close. Where it was set at factory.
Otterby
34
Jan 19, 2020 02:53 PM
bjmayberry2
May 31, 2017 09:48 PM
stuffman
20
Mar 10, 2004 02:39 AM
Polkat
Nov 19, 2002 10:47 PM
oft
Mar 17, 2001 04:21 PM
