P2290 code
Old Jun 19, 2016 | 01:44 PM
Rengland2008's Avatar
Rengland2008
P2290 code
I just did a bunch of work on my 6.0. Here's a list- head gaskets, arp studs, new heads, 2 new injectors, updated stand pipes and dummy plugs, water pump, and all new injector o-rings. After messing around with a bent pushrod, cylinder 5 code and and replacing injectors the truck runs excellent. After driving it a bit I get a code "P2290 injector control pressure too low". The truck runs great with no low power, stalls, or hard start cold or hot. Any ideas? I do puff black smoke but that's because of the sct tuner on performance tune. Any ideas would be greatly appreciated.
Old Jun 19, 2016 | 02:40 PM
LindenBruce's Avatar
LindenBruce
Okay, do you have a smart phone? If so, get a blue tooth adapter, buy it and load the program from the app store. That is the cheapest way to get some numbers. Check your ICP values and your HPOP pressures. Report back. B.
Here is a sample of the adapter I mentioned. There are others just shop around.
ELM327 V1 5 Bluetooth Interface OBD2 Auto Scanner Adapter Tool Torque Android | eBay
P.S.
Update your profile to show your city and state. There maybe people close to you that can possibly help if needed.
Old Jun 19, 2016 | 02:58 PM
Rengland2008
Icp pressure at idle is 630psi. That's all I can see with my sct tuner. Does hat pressure seem high for idle? I think it tops out at around 3500psi when I'm given her the beans.
Old Jun 19, 2016 | 04:37 PM
BLADE35's Avatar
BLADE35
you must remove the tunner to test the truck
Old Jun 19, 2016 | 05:08 PM
69cj's Avatar
69cj
Google says HPOP.
Old Jun 20, 2016 | 05:00 PM
Rengland2008
Update... Stock tune and no code so I guess it was the performance tune causing the code. I did just change the oil again so as of now, I'm good to go. Thanks by the way BLADE35 for reminding me to turn the tune off.
Old Jun 20, 2016 | 08:10 PM
Rengland2008
Changed oil again, applied sct performance tune and no more codes!
Old Jun 20, 2016 | 09:37 PM
BLADE35's Avatar
BLADE35
Give it a few days some DTC need time to trigger
lets hope its solved though
Post back
Old Jun 21, 2016 | 08:46 AM
npccpartsman's Avatar
npccpartsman
That code can be set from ICP commanded being too high too long vs actual. You can get it and the truck run flawlessly depending on programming. I used to get it going down the 1/4 mile. It was a programming trick to get max performance from the HPOP.
abowman
Feb 22, 2024 02:35 PM
Bigblockboy
17
Oct 11, 2016 07:55 PM
sudsmcduff
Sep 3, 2013 03:19 AM
mkingz
Dec 22, 2008 05:00 PM
boknows
Feb 19, 2008 03:27 PM
