getting the 1211 code after gt38r install
Old Sep 2, 2013 | 11:17 PM
sudsmcduff's Avatar
sudsmcduff
keeps popping up. truck runs fine. should i just keep driving and clearing the code?
Old Sep 2, 2013 | 11:31 PM
Stewart_H's Avatar
Stewart_H
Short of a real problem, the P1211 code is usually set when a truck with custom tunes is subjected to a hard/aggressive acceleration.
Stewart
Old Sep 3, 2013 | 12:28 AM
sudsmcduff's Avatar
sudsmcduff
Stewart
ok, it comes on in stock mode. guess will have to get used to the engine light
Old Sep 3, 2013 | 12:50 AM
hasteranger's Avatar
hasteranger
1211 is for the high pressure oil pump. The tune you are using is calling for more injector control pressure then the stock hpop can provide. Only long term solution is to upgrade the oil pump to an aftermarket unit or dual units, or try a tuner that calls for less icp. You may make more power with less icp so it's not necessarily an issue of watering down the tune. Dunno what tuner you're running now either. It's a common code and you can just live with it if you're not having any problems.
Old Sep 3, 2013 | 03:13 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
I used to get the P1211 with DP-Tunes even with my Adrenaline and currently my T500. I can't speak for others as I don't know, but I don't get P1211 with Gearhead tunes I have now.
Old Sep 3, 2013 | 03:19 AM
Stewart_H's Avatar
Stewart_H
You get the P1211 code while you're driving on the stock tune?
What about when driving on a custom tune, like your 80 econo?
Do you have AE? Can you data log?
Stewart
EMD_DRIVER
Sep 17, 2014 03:59 PM
boknows
Feb 19, 2008 03:27 PM
my69camaro2
Jul 24, 2007 01:22 AM
tommyl
Computer Chips & Tuners
Feb 10, 2004 01:51 PM
rckrwlr
Jan 25, 2004 11:46 AM
