6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Hydroboost question
Old Jun 18, 2016 | 05:13 PM
ManfredVonRichtofen's Avatar
ManfredVonRichtofen
Hydroboost question
Ive posted in two other sections on here but no info was given so i'll try here since most diesels run the hydroboost. This is on my 79 bronco
I nearly have the hydroboost bleed i think because not much air bubbles come up when i turn lock to lock. But when i push on the brake pedal several times then the power steering pump foams up. Is air in the hydroboost still causing this since it doesnt foam up when i just turn the steering.
But also my pedal doesnt come back up when i push it down. I have to bring it back up manually.
Also do you bleed the brakes first or the power steering? Assuming the power steering?
Any suggestions? Thinking about just doing a vacuum pump to purge the air.
Old Jun 19, 2016 | 06:27 AM
bubba.whit6.4's Avatar
bubba.whit6.4
Hmmm. I would bleed first since it'll be the cheapest option. I'm not sure why you would be getting air back out of the PS reservoir. My only guess would be that since your steering works fine, your HB is pushing enough pressure to it. So maybe it's just got a little air it needs to work out of the system. Just spit balling.
/3ISON
1978 - 1996 Big Bronco
Dec 27, 2016 09:41 AM
brenthottle
Jul 9, 2014 12:22 PM
chucknmesa
Feb 4, 2012 12:43 PM
sflem849
Jan 5, 2009 10:56 PM
CEP
Sep 1, 2006 06:07 PM
