2002 Ford Explorer Sport
Just started last evening when I returned home .
Closing lights low beam ( yellow & rear tail light ) did not shut.
Bell sounding
Not dealing with it last night disconnected ground cable off battery
This morning took a look
Connected ground cable too battery. Expecting low beam lights too go on. Did not .
Turning lights on & off. Head lights work fine. yellow and rear stay lit
Disconnected battery, OFF
Reconnected battery cable yellow light stays off until I turn on head lights, and will not shut off from switch
Thinking light switch ?
Could a burned out fuse in another fuse cavity cause this effect?
how can I test
my explorer and F150 have separate fuses and system for the tail lights and turn signals... Everything don't come off the head light switch like it did 20 years ago. . I would look at your operators manual and see if there was a breaker for the tail lights separate from the head lights... breaker may have stuck contacts... If that's not it, then head light switch is another possibility.
I don't see a separate breaker for this.. If a fuse was burnt out, the lights should not work at all. I think the head light switch sounds like a good place to look.
Does your Explorer have an aftermarket trailer hitch and wiring installed? If so, I'd be inclined to suspect that you have a corroded connection in the wiring installation that is causing the issues with the tail lights, particularly a suspect ground connection.
