I have a 1967 Ford F-250 I have running lights, tail lights, turn signals, and brake lights and emergency flashers but no head lights. I first thought it was a burned fuse, but they are fine. Then i thought it was the light switch and changed it. Still no head lights. Then i changed the bulbs themselves and still no head lights. Does anyone have any suggestions?
Well at this point you'd be right, with me thowing parts at it. So, tell me where would i start. the only disconnected wires i have found are branching off the three prong socket that plugs into the head lights. Is that my power source?
Start by buying a good test light. Then start tracing the power path. Might be best to test it right at the hi/lo beam switch as mentioned. Power in, no power out, you've found the culprit. Usually they are pretty toasted and crusty by the time they quit so make sure and replace the pigtail connector too.
