I was sitting in my truck with It running It never got hot. But out of nowhere It started to idle down and die now It barely starts and then acts like it's choked out and dies again. Any help would be appreciated. Thank you in advance
But, tell us about yourself and your truck. That's done to some extent by adding the location info in the profile so it shows in the upper right, and setting up a "signature" that tells about your truck. Are you really in Botswana?
Got it started. Had a dirty throttle body. Cleaned it up just adjusting the timing since it was a little off
I live in south texas. My truck is 1996 f250 5.8l with a 5 speed manual. But I lost all fuel pressure so I'm pretty sure now it's been the pump thats the problem. I know it has a new filter on it so it's not plugged up
