351M running rough...need help!
Old Oct 18, 2002 | 04:36 PM
Four Paws's Avatar
Four Paws
Okay, I have a '77 351M That is running like crap lately. I think it is in the carburetor, but here are the symptoms.
Won't rev up fast (poor throttle response), it hesitates if you give it wide open throttle, and often backfires through the carb if you floor it from an idle. It even backfires out the tailpipe at times. Under constant acceleration it often feels like it is missing. I have played with the timing trying to work it out, but that doesn't seem to help. Currently it is timed at 12 degrees btdc like the valve cover says. It has the stock Motocraft 2 bbl and mated to a NP435 manual trans.
All your help is apprciated, just point me in the right direction! Thanks, Josh
Old Oct 18, 2002 | 09:18 PM
blu93gt's Avatar
blu93gt
stock catalytic converter?
Old Oct 18, 2002 | 10:53 PM
Four Paws's Avatar
Four Paws
no cat...no polution equipment at all. Just running like crap.
Old Oct 19, 2002 | 11:49 PM
Four Paws's Avatar
Four Paws
Come on guys...
Old Oct 20, 2002 | 03:08 AM
Brian S's Avatar
Brian S
It could anything.
Incorrect timing, weak spark, bad plugs, worn dist. shaft, vacuum leak, carb, worn cam lobe, bent pushrod, stuck or broken valves, valve spings, piston or ring damage, crappy gas, should I keep going?
It's hard to solve problems long distance.
Fill us in on everything you have positively checked.
Old Oct 20, 2002 | 03:16 AM
Brian S's Avatar
Brian S
http://home.earthlink.net/~bubbaf250/2150carb/carb01.html
http://www.network54.com/Hide/Forum/163500
Old Oct 20, 2002 | 10:25 AM
shazam's Avatar
shazam
mrekab
31
Feb 13, 2015 08:29 PM
10129
Feb 9, 2015 03:39 AM
evam350
May 26, 2012 04:52 AM
Khyren
Jun 9, 2011 08:52 PM
josh83tx
17
Jan 1, 2009 10:36 AM
