Flywheel and Harmonic Balancer Offsets
Old Aug 16, 2003 | 10:26 PM
i_alone's Avatar
i_alone
Is there different Flywheel and harmonic balancer weight offsets for the 351w?, I just installed a windsor into my truck, and installed a flywheel out of an 83 Bronco, now, she has a nice viberation coming from the engine, oh yeah, and the engine is early-mid 70's so I'm wondering if there is different weight/offsets fit these engines?
Old Aug 17, 2003 | 01:43 AM
ecarter50's Avatar
ecarter50
All 351w and 81-earlier 302 are 28oz imbalance. Are you sure the 83 flywheel is from a 351w and not a 302 which looks the same but has 50oz imbalance.
Old Aug 17, 2003 | 08:56 AM
i_alone's Avatar
i_alone
I hope not, I got the flywheel from a wrecking yard, they said that it was from a windsor, now.... the ultimate question, can I change the harmonic then if it is the wrong one, to the 50 oz weight, and make it work, or do I have to change the flywheel again, I just installed this engine yesterday, and I guess this time I'll have to pull the transmission his time around if I have to
Old Aug 17, 2003 | 09:12 PM
ecarter50's Avatar
ecarter50
You have to use the 28oz 351w harmonic balancer.
Old Aug 17, 2003 | 10:47 PM
i_alone's Avatar
i_alone
but.... if I have a 50 oz flywheel, can I put a 50 oz harmonic balancer on the help it, or should I go and pull the trans and replace the flywheel with the proper one, I would like to go the first route, because I don't have to drop the trans.
Old Aug 17, 2003 | 11:36 PM
90f150moneypit's Avatar
90f150moneypit
Yes, just matchup the correct balancer with the flywheel or flexplate you have.
Old Aug 17, 2003 | 11:41 PM
i_alone's Avatar
i_alone
cool, I really hope that does it, I don't feel like pulling the trans, becasue someone screwed up and gave me the wrong Flywheel
Thanks Tom
Old Aug 18, 2003 | 06:12 PM
54at50's Avatar
54at50
you must match the flywheel and harmonic balancer to the imbalance of the crankshaft. If you have a 351w the imbalance of the crankshaft is 28oz. A 50oz flywheel & 50oz balancer will not balance a 28oz imbalance crankshaft. If you run the out of balance condition for long it will destroy your bearings.
Old Aug 18, 2003 | 06:37 PM
i_alone's Avatar
i_alone
yeah, that's what I figured, execpt no-one around here has a flywheel for a 351w engine, this sucks
Old Aug 18, 2003 | 08:52 PM
nzabka's Avatar
nzabka
NAPA and O'reilly's have them for under 50 bucks if your in a pinch. Just out of curiousity, what does a salvage yard get for a flywheel?
Another way to look at it: A $50 flywheel is cheaper than a new motor.
Old Aug 18, 2003 | 09:11 PM
i_alone's Avatar
i_alone
I picked my flywheel up for $40 at the local wreckers, I'm trying napa to see what they cost, I in some ways would like to go a new one, but... if I can find one for cheaper at a wreckers, then I'll go that route, which right now is like finding a needle in a haystack up here in Alberta
Old Aug 18, 2003 | 11:30 PM
i_alone's Avatar
i_alone
another thing, I checked the casting #'s on both the Flywheel and the Harmonic Balancer, wiht Ford, the harmonic fits a 81-83 Ford 351w, and the Flywheel, well you guessed it, fits a 81-83 302, hmmm me thinks that, that might be my problem right there
ScallyWaggler
May 16, 2015 02:03 AM
JRS2
Apr 15, 2014 08:57 PM
TPyle
Apr 12, 2014 04:45 PM
steve(ill)
Oct 12, 2005 10:35 PM
steve(ill)
Oct 5, 2005 06:09 PM
