Sponsored by: Real Truck
Mag-Hy-Tech Covers
Old Jun 16, 2016 | 10:39 AM
stufarmer's Avatar
stufarmer
Mag-Hy-Tech Covers
2015 F250 4wd. 6.2 3:73 ( plenty of power )
I'm preparing our Truck for a Florida to Alaska road trip. We'll be towing a 8k + Arctic Fox Travel Trailer. I've just ordered a new Rear Mag-Hy-Tech Diff Cover and Transmission Pan. The Diff Cover holds an additional 2 quarts of fluid. I've used one in the past and know it's worth every cent when you're towing.
The Transmission Pan holds additional 2 1/2 quarts of fluid for extra Cooling.
I've never used one of these. Has anyone ?
Is it worth it ?
Old Jun 16, 2016 | 01:00 PM
WE3ZS's Avatar
WE3ZS
Your rig came from the factory with a good rear diff aluminum finned cover that held the proper amount of oil. I don't think that the extra capacity of the Mag-Hy-Tech cover is really doing anything for you, maybe it could extend the change cycle but most guys who care enough about their rigs to have this discussion are already changing it early. Not trying rain on your parade or dispute your experience based opinion, I'm cool with differing points of view and opinions (and it's not my truck or money ). But I do run an oil temp sender and stand alone gauge for my rear diff oil. My EX has the '08+ finned OEM cover and Mobil 1 75W-140 lube which is rated up to 340' degrees if I recall my earlier research correctly. Pretty much all of my wagon's miles these days are logged towing our 11,000lb TT all over the East and the highest temp I've seen is 225. I've had the gauge for 3+ years and we tow 3 to 5 k miles a year.
As far as the bigger trans pan our resident trans expert @Mark Kovalsky has stated that the air under and around the trans pan is hotter than the cooler outlet so the pan doesn't aid in cooling at all and the additional fluid is also of limited value. Ford spent a lot of time and money sorting all of this out prior to production.
Oh, and I'm very envious of your FL to AK trip, that seems like a great adventure! How long do you plan to on the road?
Old Jun 16, 2016 | 01:19 PM
stufarmer's Avatar
stufarmer
WE3ZS;
My truck has a stamped steel cover.
We'll be gone until the House Sitter gets home sick ..
Old Jun 16, 2016 | 02:20 PM
WE3ZS's Avatar
WE3ZS
Originally Posted by stufarmer
WE3ZS;
Really? I thought that all of the trucks from '08 upward had the nice finned aluminum cover, I wonder when they stopped shipping them out with them?
Old Jun 16, 2016 | 02:51 PM
wrvond's Avatar
wrvond
My 2012 has stamped steel as well.
Old Jun 16, 2016 | 02:55 PM
Squisher's Avatar
Squisher
My '11 plain ole steel too. No fins.
Old Jun 16, 2016 | 03:07 PM
Just Strokin's Avatar
Just Strokin
I think only the dually came with the aluminum finned cover....my 2015 drw has the aluminum cover.....
Old Jun 16, 2016 | 04:46 PM
jwsrules's Avatar
jwsrules
Yup I never see trucks with fined covers most plain steel. My 2012 is steel plain one.
Old Jun 16, 2016 | 05:59 PM
Just Strokin
I believe you will find the DRW's (dually) have the aluiminum finned covers. The SRW stamped steel.
Old Jun 16, 2016 | 08:07 PM
Tom's Avatar
Tom
Starting in '08 the PSD-equipped trucks got the aluminum finned cover. I believe in 2012 or 2013 all SRW trucks went to stamped steel. Gas trucks never left the factory with aluminum diff covers.
Old Jun 16, 2016 | 08:09 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
A deeper transmission pan doesn't do a single thing except add 2.5 quarts of fluid. It doesn't help it cool, it doesn't keep the fluid cooler, it doesn't do a darn thing worth the money.
Old Jun 17, 2016 | 05:53 AM
bobv60's Avatar
bobv60
I have had Dodge, Cummins trucks for the last 15+ years. An 97, 05 and 12. The Dodge community really likes the mag hytec stuff and is real popular with them. I had them on all my trucks. The extra oil does help with cooling. The more oil the more BTUs it takes to heat it. Would you notice the difference? Probably not. But why do the diesel trucks all take 3+ gallons of oil when the same size gas engine take 1.5 gallons or less? It's for cooling.
You bought high quality parts that will look good and add some help with cooling. It is your money, you bought what you wanted. As long as you are happy with them that is all that matters.
Old Jun 17, 2016 | 06:20 AM
MisterCMK's Avatar
MisterCMK
All it does is take longer for more oil to get hot. It doesn't cool the oil.
Old Jun 17, 2016 | 06:47 AM
snoball1974's Avatar
snoball1974
Now we are in a "He Say, She Say" battle.
Old Jun 17, 2016 | 07:09 AM
MisterCMK's Avatar
MisterCMK
Is that so? Ask Mark K about it...
