Suggestions for gauges
Old Jun 30, 2016 | 12:51 PM
  #31
Diesel_Brad's Avatar
Diesel_Brad
Originally Posted by eakermeld
FITTING, ADAPTER, 1/8" NPTF FEMALE TO 1/16" NPT MALE, FOR FORD FUEL RAIL
here's a link to the adapter. If you shop around you can find one cheaper.
Too bad they doesnt work on the 92+ 460s
Old Jun 30, 2016 | 01:39 PM
  #32
Scndsin's Avatar
Scndsin
No, but on my 5.8 it should be fine.
Old Jun 30, 2016 | 01:55 PM
  #33
GuitarJesus's Avatar
GuitarJesus
Is the valve fixed in place? Doesn't make much sense, if it goes bad, you have to replace the whole passenger side fuel rail.
Old Jun 30, 2016 | 06:46 PM
  #34
eakermeld's Avatar
eakermeld
Originally Posted by Rocky Mountain F150
Hey, since you decided on an Oil Temp gauge, where's a good spot to put the Oil Temp sender in at? Curious where you and others have put it. I tried a drain screw that has a 1/8th threaded center section and it drip leaked no matter how much tape I used. Thinking it needs a bung welded into the side of the pan somewhere, but that seems like a pain in the a$$.
I have a remote oil filter on mine so I simply put the temp sender in the extra port coming out of the block.
I made this for another project. If the adapter didn't have extra ports, this could be an option. Other than that, welding a bung in the pan may be your only option.
Old Jun 30, 2016 | 07:56 PM
  #35
Rocky Mountain F150's Avatar
Rocky Mountain F150
Thanks! I think I'm gonna delete my oil filter sandwich cooler and go with a remote filter kit with dual FL-1A filters. There should be a port for a sending unit on those.
Old Jun 30, 2016 | 09:50 PM
  #36
Scndsin's Avatar
Scndsin
...a remote filter kit with dual FL-1A filters. There should be a port for a sending unit on those.
There is. I've had one of these on both of my SBFs & the un-used outlet is perfect for a temp bung.
Old Jun 30, 2016 | 09:56 PM
  #37
Scndsin's Avatar
Scndsin
Originally Posted by GuitarJesus
Is the valve fixed in place? Doesn't make much sense ...
Not sure on a 460, but can't you go aftermarket regulator with a pressure port (for gauge) on a stock rail?
Old Jul 1, 2016 | 06:23 AM
  #38
Diesel_Brad
And that is NOT what this thread was about, it was about a 92+ 460
You can replace the core just like in a tire valve stem. There is not a whole lot to go bad there
Old Jul 1, 2016 | 08:30 AM
  #39
Scndsin's Avatar
Scndsin
And that is NOT what this thread was about, it was about a 92+ 460...
Yeah, we know you pointed that out earlier.
I needed additional related information & it was provided.
Old Jul 2, 2016 | 06:01 AM
  #40
Diesel_Brad
Yes. Typically aftermarket adjustable regulators have a spot to tap in for a gauge
Old Oct 15, 2022 | 08:22 PM
  #41
savannahbochantin's Avatar
savannahbochantin
1st Gear
Low fuel pressure 03 f150 cng
Hi everyone my name is savannah and I own a CNG 03 Ford f150 5.4L and when I go to the gas pump to put gas in my truck the pump acts as if it's gonna pump gas but never does so I connected my vehicle to OBD reader at AutoZone and cod that came up was fuel rail low pressure sensor now is it that sensor I need to switch out or what exactly is it
Old Oct 16, 2022 | 06:10 AM
  #42
torq'ta 5 8's Avatar
torq'ta 5 8
@savannahbochantin - Welcome to FTE
try posting your question in the link below, it is your year, model, truck forum, you'll get it answered
1997 - 2003 F150 - Ford Truck Enthusiasts Forums
2006powerstroke90
Dec 26, 2010 01:06 PM
john8403
Oct 23, 2010 05:40 AM
phatdually1
General Diesel Discussion
Dec 9, 2006 12:29 AM
phatdually1
Oct 18, 2006 12:19 PM
TNT in Round Rock
Jun 11, 2006 07:48 PM
