Suggestions for gauges
Old Jun 16, 2016 | 08:39 AM
Lead Head's Avatar
Lead Head
Originally Posted by Scndsin
My 5.8 is spec'd @ 195* to open thermostat.
...and within that range, anything from ~190-235*F is considered an acceptable running temperature since thermostats are not an absolute thing. The Foxbody mustangs with the 5.0 don't even turn the cooling fans on until 220*F, and the high-speed fan won't turn on until 240*F.
Old Jun 16, 2016 | 09:28 AM
Scndsin's Avatar
Scndsin
By all means, run what you want or not where you want it. Or not.
Old Jun 19, 2016 | 08:36 PM
4DB's Avatar
4DB
Ford slathered the word "N O R M A L" all across the front of my coolant temp gauge. What can I learn from that? Well, for one, if I'm a blue haired little old lady, I can keep going pretty much no matter what. But, if I'm somewhat younger and still have a brain in my head, I can still make some accurate assessments and recognize when the needle isn't sitting where it's supposed to be and take some action based on the magnitude of the fault,
For example, I don't need to know that the water temp has increased by precisely 20 degrees if I can see that the gauge needle has moved from the O to the M when nothing special has changed. Either way I need to have a look at things.
My point in posting above was to try to casually point out that there are only so many practical places to put a gauge (and the dry, electronic stepper motor types are so friggin' expensive), you have to be a little conservative if you plan to go very fair with this sort of thing.
Old Jun 19, 2016 | 10:26 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Run as fast as you can from Glow Shift!
-Enjoy
fh : )_~
Old Jun 27, 2016 | 08:22 PM
GuitarJesus's Avatar
GuitarJesus
I've decided to go with vacuum, fuel pressure (perhaps a wideband 02 instead), oil temp, and transmission temp.
Also I'm going to do some of Steve83's (from Supermotors) mods on the cluster. Pre 87' oil pressure sender so the gauge actually works right, and an anti-slosh module with a low fuel light taken out of a Mark VIII, so the gas gauge doesnt move just because I step on the gas.
Old Jun 27, 2016 | 08:36 PM
Diesel_Brad's Avatar
Diesel_Brad
Originally Posted by GuitarJesus
The Ford rail takes 1/16 NPT?
No, not the 460. There is NO provisions for a fuel pressure gauge.
You need to remove the pressure regulator and get an aftermarket on with a part in it. I ended up getting a BBK one(finally a good one after 3 tries)
Old Jun 27, 2016 | 08:42 PM
GuitarJesus
Isn't the fuel pressure relief valve 1/16 npt? That's what people use for the fuel pressure gauge I thought?
GuitarJesus
Went with the BBK and not the Kirban eh?
Old Jun 27, 2016 | 09:07 PM
eagle275's Avatar
eagle275
Got a part # for that BBK gauge? Thanks!
Old Jun 27, 2016 | 09:34 PM
eakermeld's Avatar
eakermeld
The schrader valve is 1/16" npt. You just remove the valve from the fuel rail and apply some teflon tape to the threads and screw the adapter in.
Old Jun 27, 2016 | 09:36 PM
eakermeld's Avatar
eakermeld
BBK-1617
Old Jun 28, 2016 | 05:18 AM
Diesel_Brad
The 92+ 460s do not have a removable schrader valve
Old Jun 28, 2016 | 08:48 AM
  #28
Scndsin's Avatar
Scndsin
Anybody have a source for these you can give me?
Seems to be the major cost of the BBK set as opposed to the gauge.
Old Jun 28, 2016 | 06:51 PM
  #29
eakermeld's Avatar
eakermeld
FITTING, ADAPTER, 1/8" NPTF FEMALE TO 1/16" NPT MALE, FOR FORD FUEL RAIL
here's a link to the adapter. If you shop around you can find one cheaper.
Old Jun 30, 2016 | 10:38 AM
  #30
Rocky Mountain F150's Avatar
Rocky Mountain F150
Hey, since you decided on an Oil Temp gauge, where's a good spot to put the Oil Temp sender in at? Curious where you and others have put it. I tried a drain screw that has a 1/8th threaded center section and it drip leaked no matter how much tape I used. Thinking it needs a bung welded into the side of the pan somewhere, but that seems like a pain in the a$$.
