ICP pigtail splice
Jun 13, 2016 | 04:25 PM
ICP pigtail splice
I am replacing the ice sensor harness and unwed to find out what wires to splice to oem harness
The stock harness is colored coded but the new pigtail is solid blue
Any help would be so much appreciated
Thanks
Jun 13, 2016 | 04:36 PM
I may have a spare ICP pigtail (I didn't use it)I think the wires are possibly color coded but I would need to look...
Jun 13, 2016 | 05:34 PM
Quote:
Originally Posted by
Jaime74656
If u could throw pigtail in the mail that would be awesome
I can cover shipping as well
6024101608
Thanks
Rob
Jun 13, 2016 | 09:26 PM
It's just wires. Connect them in orientation to how they are in OEM plug..😉
Jun 13, 2016 | 10:15 PM
robjs111
6024101608
Thanks
Rob
If I can find it sure, the three wires should be transplantable as the post above states, just cut and splice each wire 1 at a time
Jun 13, 2016 | 10:40 PM
Jaime74656
Is the wires connected to the actual connector ?
Jun 13, 2016 | 10:43 PM
robjs111
Possible to text pics to 6024101608
Jun 14, 2016 | 07:38 PM
Just hold old plug next to new plug and connect wires to match according to location.
You know single wire to match and then the 2 lower wires.
Jun 14, 2016 | 08:32 PM
petrokiller
Problem is the oem end has been removed already so I have nothing to reference
Thanks
Jun 14, 2016 | 08:53 PM
Just pkug the connector back in. It only plugs to ICP one way
Jun 14, 2016 | 09:06 PM
This will probably help:
Jun 14, 2016 | 10:08 PM
Pikachu
That will work for sure
I cannot thank u enough
Again thanks
lhud
33
May 4, 2023 12:50 PM
Cdy1
1978 - 1996 Big Bronco
Jan 2, 2009 06:13 PM
jpbrad0215
Feb 1, 2007 11:36 PM
IAv10
All Things Towing
Mar 24, 2004 09:58 AM
