Help needed: No full turn right after lift kit
Hi all, so last week I installed a 6" lift and once we got it done I could barley turn right at all. So I decided to put a drop pitman arm on yesterday with a buddy, thinking that was the issue. But I still have the problem, and I very badly need to fix it and don't know what it is. Turning left is completely fine however. Any help would be appreciated, as it feels like I'm trying to steer an 18 wheeler right now. Thanks.
He had the problem with the stock pitman arm before changing it ant if I recall correctly the pitman arm in indexed so it will only go on one way like the slipyoke splines on the driveshaft. Although everyone seems to think its necessary to marks that to put it back together the same way. Anyways I'll check a pitman arm tomorrow to make sure I got atleast one laying around. Did you use a track bar drop bracket? And did you straighten out the steering wheel when you were done by adjusting the drag link?
LuLuGoin2ADiesel
1999 to 2016 Super Duty
19
01-12-2005 05:15 PM
