Sponsored by: Real Truck
Trailer circuit problem
Old Jun 24, 2016 | 04:00 PM
83F250Chris's Avatar
83F250Chris
Trailering
Hi all,
I sold the 83 and got myself a newer truck. A 2000 F250 CC SB 7.3. It's a great truck and I've had only minor issues. Recently I found out the the trailer right turn signal doesn't work. I found the fuse missing under the hood but after installing a fuse there is no power, even at the fuse hot side. I tried looking for a relay but I couldn't find a specific relay that controls the circuit but no luck. Everything works fine I the truck. It's only the right turn trailer circuit.
Does anyone have any ideas on where I should look next?
Old Jun 24, 2016 | 04:19 PM
Chuck's First Ford's Avatar
Chuck's First Ford
run a temporary wire from battery to fuse in fuse box... does the trailer light work.
if it does.. broken wire/bad connection between main power into fuse box and the connector for THAT fuse.
Old Jun 24, 2016 | 04:26 PM
ligito's Avatar
ligito
Test both the truck connector and the trailer connector, for a complete circuit.
Wires in connectors frequently loosen and cause problems.
Tighten any loose screws.
Old Jun 24, 2016 | 04:29 PM
83F250Chris
Trailering
I'll give that a shot and see what happens.
cflintstone
All Things Towing
Aug 11, 2015 11:37 AM
thehawk789
1997 - 2003 F150
Jun 22, 2007 11:08 PM
02mudbug
Dec 9, 2005 12:54 AM
nathanael
Jun 30, 2005 08:06 AM
Mitchiep
1983 - 2012 Ranger & B-Series
Jan 14, 2004 10:13 PM
