I just put a 1997 7.3 e4od tranny into my 1990 super duty with around 15-16 quarts of fluid. But was wonder if it was normal for it to almost kill the motor while in drive and reverse and make a rattle from the tranny after I go back to park.
Would it be not enough fluid is inside to converter yet?
The tranny is a Ford reman that was removed since the motor went out after the tranny install.
Did it bind up when bolting together? I believe you could have a problem if the input shafts got swapped around. There are two different lengths that I know of, but I am not sure you could even get the converter seated if the shaft was too long. Just my guess.
even though it's a 2wd truck,it's a 4wd trans.they hold more than you put in.the dipstick never lies.
you can't use a 6 stud psd converter.you need to use your original idi flexplate for proper engine balance and you need to use the 4 stud idi diesel converter to match it.
I was thinking that maybe to solenoid pack could be bad, even though it can out of a good core tranny from a 460.
I did post the numbers from it in another thread.
And I did use the original flywheel and a 4 stud converter.
I may add some more fluid to it in the morning. Worst I may have to do i drain some out.
Here is a link to the torque converter that I installed. As no tranny shops would sell just a converter in my area and everyone online was ridiculous on there prices.
I still don't really have a working throttle at all in gears except reverse for some reason. And when I first start it, I have to rev the motor up to get it to start moving into gear. I did add one extra quart of fluid while the motor was running in park to get it in the cross hatches.
