the starter that exploded had more metal touching the fly wheel than the other ones, so I put in my old one from the 302 that just had a small lip that would catch. Before I installed it, I just grinded that lip away.
I think you're going to want that lip. It's what indexes the starter relative to the bellhousing and flywheel. The bolts provide the clamping force, but aren't really designed to control side to side motion. In the starter housing, the bolt holes are deliberately oversized to make sure there is no side load on the bolts. Without that lip to index the starter, the starter alignment could be way off and eventually tear up the ring gear if the gear teeth aren't meshing 100%.
I'm still perplexed the crankshaft shifted around like it did but with no ill effects. Glad you got it going, but I have to wonder if it will return. Every time you depress the clutch, that puts forward pressure on the crankshaft. I'd hate to see it bind up again on you. Then again, it could be fine and run for years without trouble.
How's the oil pressure? That's a good indicator of bearing wear, and maybe by extension the condition of the thrust faces on the #3 main bearing inserts.
I couldn't tell how much it moved, as for the starter, I'll worry about that when I get there haha the guy I bought the engine off of said he still had the starter up there, so I'm gonna go pick that up and have it as a backup.. So if it breaks and blows up it's not a big deal haha
I wouldn't let that go too long. For reasons unknown, the teeth on the easily replaceable starter generally hold up just fine to a gear mesh problem. It's the ring gear that seems to take the brunt of the abuse.
That is not a laughing matter.
"I have another starter"
The starter is *not* the problem...
Shifting crank is going to destroy everything inside.
Whoever did that rebuild doesn't know a damn thing about putting an engine together.
It made it 40k miles so far so he didn't too bad, something goofy could've happened to it after he took it out of the van it was in, we'll see. If it's got a problem I'll fix it when
