6 Speed trans conversion?
Old Jun 8, 2016 | 10:12 AM
97squarebody's Avatar
97squarebody
Hello all;
It's been a while since I was around here but I have a question or two. I think I am losing the first and second gear syncros in the ZF5 speed in my 95 F350 w/ 7.3. Given I am going to have to pull the trans and put $$$$ into it, I was thinking the 6 speed used on the newer trucks would make a nice upgrade. Gaining a little more OD for the freeways would be a nice benefit.
Has anybody around here done this before? How difficult is it? Is there a conversion kit available for any of the odd parts needed? Is it a simple bolt in?
Any other thoughts or questions?
Old Jun 8, 2016 | 12:09 PM
mefast's Avatar
mefast
The ZF6 doesn't really add much OD benefit as the gear ratios are just closer together if I remember correctly. There might be a bellhousing to mate your 7.3 to a Tremec Magnum (or a TR-6060 or T56 if they have the torque capacity), but its usually in the $3000 price range for those transmissions. I'm not good with autos, but I believe most of the 6 speeds require a control module if available at all. Those will likely be pricey as well. It would be cool to see someone make the swap though.
Old Jun 8, 2016 | 01:22 PM
GoinBoarding's Avatar
GoinBoarding
Zf5 OD should be 0.77:1 while the ZF6 should be 0.72:1. So you'd gain some extra OD. That's my only useful input.
Old Jun 8, 2016 | 02:15 PM
snowdog79's Avatar
snowdog79
I know the bell needs to be modified at least. I did some research into this when I got my truck - the ZF-6 is relatively common in yards around here - and I couldn't even come close to justifying the cost vs. any potential fuel savings. Of course, there was nothing wrong with my ZF-5, so I would have just been doing it for the small OD improvement. Maybe it's more reasonable if you have a trashed transmission you need to replace as the actual cost for the tranny isn't outrageous.
Old Jun 8, 2016 | 02:26 PM
'89F2urd's Avatar
'89F2urd
7.3 zf6 will bolt right up.
Zf6 vs zf5 is night and day difference in drivability with the extra gear, and mileage is noticeable if you do a lot of accelerating vs highway driving.
Zf5s have a garbage 3 acceleration gears, 4 is a huge difference.
You'll need tunnel mods, but way worth it IMO.
Old Jun 8, 2016 | 02:56 PM
97squarebody
I know the bell housing will work just fine as they were factory from 99 to 2002 behind the 7.3. That is the easy part. I am more concerned about things like cross members, drive line length + yoke compatibility, speedo drive, an shifter location.
These are the big questions for me.
When "tunnel mods" are mentioned, What is meant by that?
Old Jun 8, 2016 | 03:32 PM
GoinBoarding
Your speedometer is dependent on the VSS, located in the rear axle, so nothing to worry about there. I read on a diesel site that you'll need to run a SD clutch, due to input shaft differences between the OBS ZF5 and SD ZF6. Also that you'll need a different cross member, but no details there. I'm sure others (those experienced with the swap) will fill in the rest.
Old Jun 8, 2016 | 03:44 PM
'89F2urd's Avatar
'89F2urd
You'll have to cut the trans tunnel out and make it bigger to install the towering zf6.
Remove seats and carpet, cut trans tunnel out across the length of the trans, install zf6, build new tunnel around trans.
Old Jun 8, 2016 | 03:48 PM
97squarebody
That is great! it solves one of the biggest issues I was worried about.
That is a manageable issue as I am not going that far into the trans and leaving a worn clutch in place.
I am hoping for just this.......
Old Jun 8, 2016 | 04:03 PM
'89F2urd's Avatar
'89F2urd
Everything is pretty straight forward....you'll need to shorten rear shaft, lengthen front. Get the t case off the zf6 so you know what components you'll need for yoke and u joints.
Old Jun 8, 2016 | 06:34 PM
Diesel_Brad's Avatar
Diesel_Brad
You will need a T-Case from a MANUALLY shifted truck and from behind a ZF6
The auto trans t-cases use a different spline than ZF6
Also, have you priced a ZF6?!?!? Yards around here get 2k for one
A FULL rebuild on your ZF5 around here is under $500
Old Jun 8, 2016 | 08:31 PM
'89F2urd's Avatar
'89F2urd
2k for a junkyard zf6!? I need to come there and sell some.
Old Jun 9, 2016 | 04:26 AM
Diesel_Brad
Actually $2200
I just sold one of my ZFs for 2k and had a waiting list of people to buy it
Old Jun 9, 2016 | 09:36 AM
97squarebody
Wow! 2K?
This might be a test of my scavenger skills because $2000 is not happening.......
Old Jun 9, 2016 | 10:02 AM
'89F2urd's Avatar
'89F2urd
It all depends on what kind of access you have to parts. I've gotten two zf6 for literally 130 bucks a pop at you pull jy ' s, they're in the business of scrap with part sales being icing on their cake. Part recyclers are going to charge a lot more for anything, just cuz they can. Their volume of zf6 and local demand will dictate what they charge
I've also gotten wrecked trucks for 3-4k, after selling everything it's a free trans and misc parts.
Martin Torres
Nov 26, 2018 10:05 AM
tinman52
Large Truck
Sep 5, 2012 08:23 PM
Greg5OH
16
May 12, 2012 07:50 PM
'83f3fiddy
36
Mar 24, 2011 08:24 AM
conrad kornell
Jul 29, 2003 02:36 PM
