4 speed or 5 speed trans?
Old Feb 15, 2010 | 09:19 AM
'83f3fiddy's Avatar
'83f3fiddy
I'm trying to get away from this blasted 3 gear trans...im wondering what would be cheaper...4 spd or 5 spd trans...and what all is involved in getting the trans to bolt up to my 83 f-350..with a 351W
Old Feb 15, 2010 | 09:55 AM
Franklin2's Avatar
Franklin2
4 speed will be cheaper, because nobody wants to swap them in. The big thing now is overdrive, and really the only tranny you can swap in a f350 that has overdrive is a zf 5 speed. It will give you a overdrive for good highway cruising. A 4 speed will only give you a 1 to 1 ratio in high gear, the same as you have now, I am assuming you have a c6. You can swap in a 4 speed manual, but if you are going to the trouble, I would swap the 5 speed in.
Old Feb 15, 2010 | 01:58 PM
86bigred's Avatar
86bigred
i agree with Franklin2,don't put in the srod trans(4 speed od trans)it's great for commuting,but sucks if you have to haul or tow anything,it won't hold up.Ford doesn't recommend towing with this trans.it's great in my dd,but any hauling i have to do,i do with my f250.IMO
Old Feb 15, 2010 | 03:03 PM
'83f3fiddy's Avatar
'83f3fiddy
well im trying to find something thats cheap and solid...its a 1983 f-350 and i dont really feel like pouring a ton of money into the trans..
Old Feb 16, 2010 | 09:39 PM
kregalmach1's Avatar
kregalmach1
yea 82 4 speed to 5 speed help please wat year
i want to make my 82 sweet truck a 5 speed its a 3 over drive now from behind a 6 cyl. but i now have a 72 351 cleavland infront of it i want to make it a 5 speed is there a non hydrolic clutch 5 speed tranny for a 302 that i can get and wat year been waiting for days for an answer to this ? but no one knows help
Old Feb 16, 2010 | 10:15 PM
'83f3fiddy's Avatar
'83f3fiddy
there should be, but why non hydro??
Old Feb 16, 2010 | 10:36 PM
Franklin2's Avatar
Franklin2
All the truck 5 speeds are hydraulic clutch, no getting around it.
Old Feb 17, 2010 | 12:01 AM
86bigred's Avatar
86bigred
you could always put a t5 out of a mustang,but they are cable clutch.some one on here did the conversion can't remember who though.i think they converted to hydraulic.
whats wrong with hydraulic clutch? they are low maintenance,no adjusting.
Old Feb 17, 2010 | 07:50 AM
'83f3fiddy's Avatar
'83f3fiddy
probably a ton cheaper, and the weak fire-wall issue with the low 80's year that i heard about
Old Feb 17, 2010 | 09:21 AM
86bigred's Avatar
86bigred
I think ford still sells the reinforcement kit for the weak fire wall.hydro IMO is just simpler and easier.and those kits are cheap as well.so why not go with hydralic?
Old Feb 17, 2010 | 10:31 AM
Rogue_Wulff's Avatar
Rogue_Wulff
Interesting seeing the firewall reinforcement kit still being mentioned. My father was a Ford truck mechanic back in the early 80's, and made his own firewall repair kit, prior to Ford copying it, and selling it over the counter. Too bad they never gave him more than an "Attaboy" for the template........
Old Feb 17, 2010 | 02:49 PM
'83f3fiddy's Avatar
'83f3fiddy
wow that's messed up..i know im gonna do a reinforcement when i go to a 5 speed
Old Feb 18, 2010 | 10:51 AM
Redneck1465's Avatar
Redneck1465
The 4spd is essentially a 3sp manual with a granny low (some are) either way your not going to gain much unless you go to a ZF 5spd.
Old Feb 18, 2010 | 10:53 AM
Redneck1465
Correct me if I am wrong but the 351C will not bolt up to a 5spd from a 302 becuase they were all the bellhousing for the 302,289,351W bellhousing and the cleveland is a different bellhousing all together.
Old Feb 18, 2010 | 11:07 AM
Rogue_Wulff
You are wrong. 351C uses the small block (windsor series) pattern, while the 351M/400 uses the 429/460 pattern.
