zf4 or zf5?
Old May 11, 2012 | 05:12 PM
Greg5OH's Avatar
Greg5OH
zf4 or zf5?
says its from an 89...should be a zf 5 no?
really want to buy this if its a true 5 speed...
ZF 4 Speed manual overdrive transmission - Ontario Transmission, Drive Train For Sale - Kijiji Ontario Canada.
Old May 11, 2012 | 05:19 PM
Greg5OH's Avatar
Greg5OH
also never heard of a ZF 4, only ZF5. older trucks came with t19s...
I called, he said its 4 speeds total with a 0.737 OD ratio..
Old May 11, 2012 | 05:20 PM
91dirtydiesel's Avatar
91dirtydiesel
Should be a zf5. 4 speeds + overdrive ? Probably what he is saying?
Old May 11, 2012 | 05:35 PM
hairyboxnoogle's Avatar
hairyboxnoogle
Ya that doesnt make any sense.. unless theyre over complicating things... like people who say a 4 speed is a 3 speed because first is Low...
Back in the 70s and maybe 80s they did put 4spd OD trans in pickups, i believe they were only in half tons. Drove one once... talk about horrendous gear spacing.
Old May 11, 2012 | 05:42 PM
Greg5OH's Avatar
Greg5OH
Ah hea said"well i think its a 4 speed"
im going to go scoop it up tonight )
Old May 11, 2012 | 05:45 PM
91dirtydiesel
I don't think there was ever a "zf" 4 spd manual
Old May 11, 2012 | 07:47 PM
Ford_Six's Avatar
Ford_Six
That's a 5speed. They probably got hung up on the way Ford labeled 5th as OD.
Old May 11, 2012 | 11:34 PM
Greg5OH's Avatar
Greg5OH
What a steal!
got everything for 260, and when i say everything i mean clutch with tons pf meat, dualass fw, clutch amd brake assembely, floor plate for shifter, block playe, slave cyl, manual steering column with a grant wheel..
how much do e4od go for?
Old May 11, 2012 | 11:38 PM
91dirtydiesel
U get crossmember too?
Old May 11, 2012 | 11:48 PM
Greg5OH's Avatar
Greg5OH
dont think so
Gotta check the box again.
i got a welder at home, could modify auto brace?
Old May 11, 2012 | 11:56 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
Originally Posted by Greg5OH
What a steal!
thats the most popular way to solve the E40D's issues.it's way cheaper,though generally not so extreme lol.nice deal!
sadly,your E40D is just good for a core,in it's current undiagnosed state.
not to worry though,you made out like a thief anyway.just hope you don't end up in jail now.
now you just have one problem.......what would it have cost in the end to find out why the tccs wouldn't lock the converter up in the truck,even though it checked out good while out.........
ah well,for the $ on the ZF, i wouldn't loose too much sleep over it.
happy shifting!
Old May 12, 2012 | 12:10 AM
91dirtydiesel
dont think so
Probably, what about drive shafts?
Old May 12, 2012 | 09:09 AM
Greg5OH's Avatar
Greg5OH
He didnt jave a ds, i will have to source one probably.
as for
My auto, its actually in good shape, when i put the solenoid pack back in and took it for a spin everything was going great! Tc locked up, stayed locked on decel down a hill, but mu worst fear was confirmed, i was driving it hard and the tc started slipping very soon after i started driving. When ur easy on her it would take a little while for it to slip.
Internal leakage of the converter
Old May 12, 2012 | 09:49 AM
Greg5OH's Avatar
Greg5OH
Do you know of the current ds has enough rangle on the slip yoke to accomodate the extra needed length?
Old May 12, 2012 | 10:31 AM
91dirtydiesel
When I did my swap I was 4x4 and I think there was enough splines to get by...but just barely...maybe an inch or 2" of engagement....I didn't try it. Here are some pics with lengths...
Front drive shaft to show how long e4od is compared to zf5
Here is how the much room the splines have
I'd just get the right shafts or get it made
