5th wheel package
Old Jun 10, 2016 | 04:54 PM
  #31
petei's Avatar
petei
Houston TX
Old Jun 10, 2016 | 05:10 PM
  #32
EightySecond's Avatar
EightySecond
I laughed, I'll admit it.
Old Jun 18, 2016 | 08:20 PM
  #33
petei's Avatar
petei
Ford executive are you check this forum?May be you can help with the question people ask and one is me.
Old Dec 22, 2016 | 03:33 PM
  #34
ATP Pilot's Avatar
ATP Pilot
Originally Posted by petei
The 2011 2X4 I ORDER IT COME WITH 5TH PACKAGE WHY THE 2X4 2017 DON'T,THE 4X4 COME WITH ONE.IT IS A LOT OF LABOR TO INSTALL IT AFTER.The bed need to be remove and drill for the electrical connection and pucks.
same feeling here, not getting new super duty until I can order the prep on the 2wd truck.
Any updates? is Ford going to fix this issue?
Old Dec 22, 2016 | 03:58 PM
  #35
mhoefer's Avatar
mhoefer
When you do a custom order, through your dealer, they should be able to over ride the order on a Short bed 2*4. Get the fifth wheel prep, it cuts the holes for both fifth wheel rails under bed mounts, and gooseneck and adapt from there to the B&W. Then you get the in bed 7 pin plug. If your ordering, make sure to get your dealer to do the Linux bed liner on site, otherwise the wait is longer for your truck I hear. There is no reason why a crew short bed in that trim can't be done. If your dealer wants a sale, they will work it out.
Old Dec 22, 2016 | 04:02 PM
  #36
System's Avatar
System
Prolocutor
Sure, a dealer can install it themselves as part of the sale but they will charge you for it. You can't order it on the 2x4 from the factory though.
Old Dec 22, 2016 | 07:19 PM
  #37
petei's Avatar
petei
Ford don't listen to the customers I end up order the package from the dealer to install it by myself .Looks that will be a little tough because is no room.I will see.
ytechie
Mar 2, 2018 06:45 AM
truckzilla 34
Oct 11, 2017 11:10 AM
Rheingar
All Things Towing
32
Mar 10, 2017 01:04 PM
PrinceValium
Dec 22, 2016 01:41 AM
Northbrook
Apr 14, 2011 09:31 PM
