5th wheel package
Old Jun 7, 2016 | 03:40 PM
petei's Avatar
petei
5th wheel package
I was at the dealer to order a 2017 F350 but the dealer can't find the 5th wheel package.Anybody know that package is standard or is option .What is the code for that.Thank you.
Old Jun 7, 2016 | 06:56 PM
Kenv's Avatar
Kenv
Code "15L" 18k SRW.... Code "15K" 27.5K DRW....
Old Jun 7, 2016 | 09:08 PM
petei's Avatar
petei
Kenv,the code is for the hitch or for 5th wheel connection?
Old Jun 7, 2016 | 09:29 PM
Kenv's Avatar
Kenv
Maybe this is what you're looking for:
5th Wheel/Gooseneck Hitch Prep Package (NA w/85B Stowable Bed Extender, 85L Drop-in Bedliner or 85M Bed Mat; 4x4 only; 4x2 is available by dealer installation – consult your dealer)
53W
Old Jun 7, 2016 | 09:31 PM
Kenv's Avatar
Kenv
Here are the other two from the guide:
5th Wheel Hitch Kit-15L – includes 18k rated hitch for SRW. (req. 53W 5th Wheel/Gooseneck Hitch Prep Pkg. and 8-ft. box; NA w/85L Dropin Bedliner or 85M Bed Mat; 4x4 only; 4x2 is available by dealer installation – consult your dealer)
15L
5th Wheel Hitch Kit-15K – includes 27.5k rated hitch for DRW (req. 53W 5th Wheel/Gooseneck Hitch Prep Pkg. and 8-ft. box; NA w/85L Dropin Bedliner or 85M Bed Mat; 4x4 only; 4x2 is available by dealer installation – consult your dealer)
15K
Old Jun 8, 2016 | 08:16 AM
petei's Avatar
petei
Kenv, the 53w is standard or option on 2017 F350 DRW.DEALER DON'T KNOW.
Old Jun 8, 2016 | 09:32 AM
System's Avatar
System
Prolocutor
It is not standard on any configuration.
Old Jun 8, 2016 | 09:33 AM
2009kr's Avatar
2009kr
I noticed that you can't get the 5th wheel hitch what ordering the swb. That seemed odd to me. Maybe they don't want to be liable for broken rear windows if someone tows with a square front fifth wheel trailer?
Old Jun 8, 2016 | 09:36 AM
System's Avatar
System
Prolocutor
Sure you can. You just can't order it on a 2wd SWB.
Old Jun 8, 2016 | 11:02 AM
2009kr's Avatar
2009kr
It doesn't show up as an option when I build a SWB crew king ranch 6.7 4x4.
Old Jun 8, 2016 | 11:14 AM
System's Avatar
System
Prolocutor
I can build it with that option no problem.
Old Jun 8, 2016 | 12:08 PM
Frantz's Avatar
Frantz
As Karl said, you can't factory order the hitch kit with 4x2, however, the order guide shows "4x2 is available by dealer installation - consult your dealer". Perhaps your dealer (or maybe just your salesmen) isn't the right one to go to. Frankly I would probably not use Ford myself and just let my local 4x4 shop do the install because they do things for me at a lower labor rate than in house and then we can pick whatever brand parts you want.
Old Jun 8, 2016 | 01:45 PM
2009kr's Avatar
2009kr
The option to buy the 5th wheel prep is there; the option to buy 18K fifth wheel hitch kit itself is absent. You will find on the LWB, but not on the SWB.
Old Jun 8, 2016 | 01:52 PM
System's Avatar
System
Prolocutor
Ah, I didn't know you wanted the hitch and thought you just wanted the prep. My mistake. I was assuming because most buy the Reese Elite without the Ford sticker on it to save money that you were just looking to order the prep. If you didn't know, the Ford hitch is just a re-labeled Reese Elite that Ford puts a part number on and marks up.
Old Jun 8, 2016 | 01:56 PM
petei's Avatar
petei
The 2011 2X4 I ORDER IT COME WITH 5TH PACKAGE WHY THE 2X4 2017 DON'T,THE 4X4 COME WITH ONE.IT IS A LOT OF LABOR TO INSTALL IT AFTER.The bed need to be remove and drill for the electrical connection and pucks.
