What year?
Old Jun 8, 2016 | 05:08 PM
Iplumber's Avatar
Iplumber
Thank all you guys for the info. I'm almost 100% sure it's a 79 chassis but still not sure what year body. There is not a plate in any of the mentioned locations. Can anyone be sure of the year by the pics alone?
Old Jun 8, 2016 | 05:19 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Painted grille is from a 1964 Standard Cab, but the truck is a Custom Cab which would have had an anodized aluminum grille.
But the 1961 thru 1966 grilles can be swapped. 1961/64 grilles have the parking lamps in the grille, 1965/66's have the parking lamps in the upper grille panel.
All 1961/64's, 1965 F100/250 4WD, 1965/66 F350/1100, 1966 F250 4WD have a large cab step visible when the doors are opened.
No cab step: 1965/66 F100/250 2WD & 1966 F100 4WD
Custom Cab door handle guards introduced in 1963, used thru 1966. When factory installed, Ford did not install side mouldings.
Without the door handle guards, 1961/66 Custom Cabs have Custom Cab nameplates on the doors, just below the side windows.
robertkernahan729
Sep 17, 2018 07:27 PM
Sawsall
Feb 12, 2008 07:57 PM
JByrd1173
Jun 28, 2004 01:03 PM
79 posi
Jun 9, 2004 10:33 PM
fatfenders
Nov 28, 2002 10:10 PM
