Crank/No Start 6.0 Excursion
I posted this in the Excursion section but posted it here in hopes for some additional help.
I have had some trouble starting my 2005 6.0 PSD Excursion recently and it happened again last night. I will provide some details as I am hoping for some guidance.
I believe that all Exs came with 2004 motors(my sticker says 2004 as well)
The Ex has 218000 miles and I have done the following work to the diesel. Two years ago I did the headgaskets, ARP studs, replaced the standpipes and dummy plugs, ICP regulator, oil cooler, HPOP pipe, injector O rings, HPOP O rings, 203 thermostat, rebuilt alternator, two new batteries, clean grounds and a 6.4 starter.
The diesel has had the EGR deleted, MBRP 4" aftermarket exhaust, has Shell Rotella coolant and runs the Tow/Haul program off of a SCT3 programmer. I use Shell 5W40 synthetic and always change the oil around the 6000 mile mark. My girl normally runs like a champ and I love driving it.
When it doesn't start I hook up a Scangauge II and check the following with KOEO: ICP, IPR, SYN, FICM volts
Results are respectively 0, 14.4, 0, 48.5
When cranking the ICP varies(but below 500 ), 28, 1, 48
I checked the codes last night as well and came up with P2614( camshaft position output circuit )and P2623(Inj control pressure regualtor circuit/open).
I also unhooked the ICP wire to see if it would start just to get it home to the shop but it made no difference. Am I looking at a HPOP?
Any help would be really appreciated as I don't trust her right now and I do not want to get stuck like this up north at the cottage.
Thanks,
Rob
Remove the oil filter cap and oil filter. Crank the engine while looking into the bowl. The oil filter bowl should fill fairly quickly. If it does, do an air pressure test to check for leaks in the high pressure side. It may be the high pressure pump.
BUT Clarify did you check DTC before unplugging ICP Just need to be sure you got the right one unplugged I guess
Nevermind the P2614 for now you showing sync of 1
Don-I will do a low pressure test in the morning as I have it back at the shop now and it still would not start. The ICP did crank up to 640 psi for a second and the Ex grunted a few times but it would not start.
I will look into what type of fittings I will need to do for a high pressure test.
Blade35-I can't remember if I checked the codes before or after I unplugged the IPR-it was 2:00 am when this all happened. I did erase everything and have since tried cranking so I will look in the morning if that code is set again. If it is it may be a bad wire?
Rob
Rob
that will determine some of the HPO parts since I cant remember the change dates
P2623 – Injection Control Pressure Regulator Open
This has to be Troubleshot ^^it means theres no electrical signal to you IPR (Shorted wire)
!CP: 100
SYN: 1
FICM 48
IPR: 78
I also took the oil filter out and looked at how quickly it filled up during cranking while holding the self drain down and it fills up quick. Can I safely say that the low pressure pump is OK?
I also modified a socket this morning to remove the IPR and I was going to do that next.
First I have to fix the kids' 2005 Escape as it has a crank/no start condition as well!!
I am ready to start waving the white surrender flag about now.
Rob
LPOP will call it ok for now
Post ICPV @koeo
And are you still at IPR% of 14.4 @ KOEO
Clear the P2623 and see if it returns it's continuos monitored so should return fairly fast if there a problem
When you pull the IPR push Inside the valve with screwdriver it should move stiffly about 1/8" or if the screen is blown out or pushed up inside
IIRC should ohm out at 6 ohms
Last time I checked the IPR% with KOEO it was at 14.4.
Should I put the IPR back in and can I crank the motor over if the FICM is off? If that is possible I can do a few more checks.
Rob
So with that said there could be no IPR contamination when you unplugged ICP sensor
P2623 needs to be pinpoint test check it's harness is it fully seated into the valve
Can you ohm the harness
Check it from PCM for short to ground on both IPR wires
Does it change it's mind when you wiggle the IPR harness
