New plug wire install
Old Jun 4, 2016 | 05:35 PM
My1964ford's Avatar
My1964ford
Hey guys I was just given a set of high temp plug wires to try and install on my 292. I want it to look nice and clean but I'm not sure how to do that. What is the cleanest way to run the wires so it doesn't look like a tangled mess or the wires were just thrown in there? I want it to look professional.. Thanks in advance!
EDIT: forgot to mention I'm running headers
Old Jun 4, 2016 | 07:41 PM
ihcc104's Avatar
ihcc104
With headers on the 292, there arent really any good places to have looms to hold them, I ran mine using little plastic spacers and then when the head behind the motor they are pretty much hidden by the firewall.
Mr. Gasket 3676 - Wire Separator | O'Reilly Auto Parts
Old Jun 5, 2016 | 10:35 AM
daveengelson's Avatar
daveengelson
Imagine there are a number of differing confiqurations; I prefer the horizontal rail type over the standard loom, find they cost more. Looking forward to other member's suggestions??
Old Jun 5, 2016 | 11:26 AM
Tedster9's Avatar
Tedster9
Tried to dig it up, somewhere over at Y-blocksforever.com forums somebody asked the same question, and Ted Eaton and others had a dozen different pics of plug wire routing on race engines that looked great. You should try to find that. My googlefoo mad skillz aren't what they once were I guess.
Old Jun 5, 2016 | 01:08 PM
My1964ford's Avatar
My1964ford
Thanks so much for the input! I'll try to work on them today and post a pic of what I come up with
Old Jun 5, 2016 | 02:40 PM
ihcc104's Avatar
ihcc104
This one would look nice, but not probable with a Y-Block... we only have 2 studs that hold the valve covers on in the middle, no bolts around the rim :/
Old Jun 5, 2016 | 04:20 PM
daveengelson
My 65, with the 390, has the 2 hole horizontal wire loom, difficult to determine but as best as I can tell the measurement between the two lower valve cover mounting holes is approx. 8 3/4". Learned from experience, online Ford part supplier's are not equipped to give advise if their website item application description varies from intended use. I would not purchase unless I was certain, perhaps able to determine by comparing FE big block valve cover, or gaskets to that of the 292. Another option, perhaps a member in the y block forum can help; but again, sometimes requires thinking out of the box.
Old Jun 6, 2016 | 04:05 PM
charliemccraney's Avatar
charliemccraney
The factory style wire looms should work perfectly. They should be available from any company dealing in vintage Ford parts.
Old Jun 7, 2016 | 03:19 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The type that holds 4 wires: FAA-12297-A .. available NOS and from repro parts sellers.
Old Jun 7, 2016 | 04:08 PM
ihcc104's Avatar
ihcc104
Wonder if anyone has a pic of how the stock holders were mounted... wonder if they will still work with headers as I and the OP have
Old Jun 7, 2016 | 04:17 PM
NumberDummy
Ask and ye shall receive.
The FAA-12297-A plastic wire retainers (4 wires - noted in post #9) are not shown in the pic (I have a car pic with them), were introduced in 1952 Lincoln's, the first FoMoCo vehicle to have a Y block V8.
They can be used on anything.
This 302 was a Lincoln derived Y block installed in 1956/63 F700/950's.
Old Jun 7, 2016 | 04:22 PM
charliemccraney
The stock looms will work with headers.
Some pictures can be found here:
http://forums.y-blocksforever.com/Topic121912.aspx?
Old Jun 7, 2016 | 10:59 PM
Tedster9's Avatar
Tedster9
That's the one! Thanks Charlie.
timbuctooCal
Jan 2, 2014 11:11 AM
Mikulh
Jul 18, 2012 09:42 AM
SoCar72
Jul 25, 2011 08:41 PM
Phity Five
Oct 27, 2005 02:36 AM
MudinMan19704x4
Texas Chapter
May 9, 2004 09:46 PM
