Sd rear spring swap
Old Jun 4, 2016 | 11:55 AM
7240powerstroke's Avatar
7240powerstroke
Sd rear spring swap
I have a 96 f250 powerstroke and I'm wanting to build it into a hauling truck. I am going to be doing a sd axle swap on it got everything I need but the shocks so any info would be greatly appreciated and also was wandering what I will need to do to put sd springs in the rear
Old Jun 4, 2016 | 11:58 PM
farmert's Avatar
farmert
What year superduty axle do you have? Did your 96 leave the factory with a pickup bed? If the superduty axle is from a pre 99, and your 96 left the factory with the pickup bed/box the superduty axle will be to narrow for the 96, as the pre99 superduty were cab and chassis trucks that have the frame rails closer together. If you are trying to put a dually rear axle under a single wheeled truck, get an axle from a dual rear truck that left the factory with a pickup bed/box, as those trucks had the wider axle to fit the wider spaced frames.
Holdmybeer
Feb 15, 2019 05:33 PM
Robert6401
Oct 24, 2016 11:46 AM
grizzly11
May 15, 2012 01:53 PM
james.mcafee1
Mar 16, 2010 08:32 AM
Shepmech
Jun 8, 2006 06:02 AM
