Potential New 6.7 Guy
My son wants to buy my 08 6.4l. I am considering doing this and if so that means I need a new truck...
So I would naturally move into the 6.7 world. I am not about to plunk down 70k for a 2017. So can I get a pointer or two of the good and bad of the current run of 6.7's? I am assuming a used 2016 would be my best bet hoping that any bugs have been worked out in the last few years?
Thanks in advance!
I love my 15. Getting close to 25K miles.
If you research you'll see issues regarding the "jackhammering" sound on the 15+ trucks. Ford has a fix that is covered under warranty should that occur on your truck. The biggest issue is there is far more misinformation about this problem that has circulated the forums than anything else. I had the repair done on my truck, it runs just fine now. The biggest change was the calibration and how it handles the regens. It now fuels both banks on regen, rather than just the driver's side.
Other than that, they've been pretty solid. I plan to keep mine for quite some time.
I'm also still trying to find out what difference it makes in regen frequency or duration. Also, if I take my '15 in for a routine reflash, will they do this, is it part of the standard code set now, or something only done to those trucks with a complaint, and other trucks will get a different reflash without this change?
They aren't hitting pistons at all. Let's just get that out of the way right now since that was a major point of argument on some past threads. I've already looked at mine. Zero contact. The tech that worked on it confirmed as well. So that rumor can be squashed. Mine isn't the only one that has had numerous "jackhammer" events with zero valve to piston contact.
It's also not an issue with the guides, or improper valve clearance. Everything is within spec.
What is happening is with the regen on only one side, there's excess buildup on the valves that will prevent them from closing completely while fuel is being dumped midway through the regen. That buildup over time can be mitigated by driving style, fuel quality, etc, which is why not all trucks experienced this. It happened mostly with the 15's and up because the regen process varies a bit from the older trucks thanks to the different turbo setup, increase in power, etc... so they got just enough of a buildup to cause the issue.
This is also why some owners had the heads replaced, only to have the issue pop back up again.
Because the regen now happens on both banks, most people have reported a change in the amount of time it takes to complete a regen, and also have noticed a difference in fuel economy where it's not dropping as drastically during a regen has it has with prior calibrations.
I don't have a big trailer but I have a 2016 23' Genesis toy hauler. The truck pulls it like it's not even there. We went to pick the trailer up new and my wife was following me home. She called me and asked if I knew I was doing 85 MPH? I looked down at the dash and she was right, lol.
The urea DEF is new to me. Neither of my 350's had it but it's not that big of a deal. Just don't spill it on the toes of your boots, it turns white.
Hope this helps with your decision.
Yes the calibration update is routine and is included with all current versions of IDS. Take your truck in for a complaint on the regen and the dealer will flash it. The TSB has the calibration update covered under warranty. Replacing the valves is optional, and if you have continued to experience the engine rattling recently, it's probably a good idea to have the valves replaced. If it's been infrequent or hasn't occurred in a while, you can probably skip the valve replacement.
My 15 has not been affected by any of the regen problems. Am I understanding this right? When I take my truck in for service they will perform the flash regardless?
The flash seems like a good thing.
I think the flash is the most important part. Not all dealers perform calibration updates regardless of what it's in for. Some places you have to ask. Just depends on how good the techs are.
And there is more misinformation than actual information on the interwebz....
