After a few minutes of driving, sometimes the headlights just go black all on thier own. sometimes I can cycle the headlight switch and they return, most of the times they do not. If I pull the column HIBEAM bar towards me and hold it in, the brites stay on. If I push it away to keep the brites on, nothing happens.
Sometimes after a couple of minutes the low beams return, otherwise I am driving home with my left hand holding the HIBEAMS in. (makes for interesting driving since its a manual)
Any ideas where this short could be? Could it be just a faulty headlight switch? curious if anyone else ran into this before.
I'd try checking wireing on the low side first. I had a pinched wire from the battery shifting once and that shorted out the lows beams. Other than that, it could well be a bad switch.
Sounds like you need a new headlight switch, the switch has a set of points in them that sometimes get burned, then they overheat from bad contact & open causing your lights to go on & off as they heat & cool. Although they usually cycle on & off fairly quickly.
Yes, but, doing what you are doing has probably melted a contact in the turn signal switch too. You have to pull both, otherwise you will risk nuking the good headlamp switch when you replace it. If the headlamp switch has a melted or watery looking connector, there is a good chance the switch in the column is bad now too.
It will be fairly obvious on the high/low beam switch because the wire connector will be melted.
The headlight switch and it's connector are notorious for this problem eventually. I wound up having to replace part of the park light wire and using a female blade disconnect and butt connector to negotiate a permanent fix after nearly nuking my new headlight switch. If you'd rather buy a pigtail and replace the connector in full, that works too. I didn't see any problem signs on my multi-function switch in the column - I must've caught it before it got too bad or it was the fact that it was the park light circuit and not the headlight circuit that was faulty and already burned a little. I'd go ahead and check it all out just to make sure.
BTW, the '89 I recently bought has ~204k on it, but is the possible victim of a bad mechanic or a cracked head. Won't know until I get back to the States and go pick it up and tear into it. I'm hoping it's a blown gasket due to re-use of the head bolts, but if not, it's time for WP heads and a few other things
My passenger side has started turning off by itself on the low beams, but I found out why. Turns out the original owner installed the 2 100-watt halogen off-road lights by splicing into the low beams direct from under the column. I took the pull-**** out to look at it when I was installing some new gauges and I've got wires melted all over the place back there and oxidizing. It stinks, now I have to find out a way to replace all of these wires.
They sell new pigtails with the connector for the headlight switch - that should help in repairing that part of the issue. I agree, might as well 'upgrade' to a relay-operated setup on your headlights. The factory wiring harness just isn't very forgiving for higher-powered lighting. I'd never wire up driving lights to those circuits UNLESS it was via a relay. Hope you get 'er figured out, Romer! Same goes to you, Wild!
