Hey I haven't used my gn ball for probably 3 years went to pull it out and flip it over to use it and it is stuck solid. Tried pb blaster trans fluid hammering on it jacking the truck up by it heating it and no go. Any ideas on how to get it out.
My other truck did this. I spayed the ball with penetrating oil and let it set over night. I was able to work it out from there. Dirt and rust really seizes them in there.
Yup -- took quite a bit of PB and time, and banging on it.
Now the thing to do is clean it and and the receiver all up and grease the crap out of everything! When I put mine back upside down, I also put plastic over it to keep water out (had a bed-liner with just a hole in it for the B&W, so tucked the plastic under that...
But really, it is lots of grease that kept it from happening again...
