B&W Turnover Ball Completely Stuck:(
Ok, so I've got a B&W Turnover ball gooseneck hitch in the bed and was planning to buy some drywall for a project this morning so I needed to remove the ball to get a flat bed - easy, right? Nope.
I can't seem to get the ball out of the receiver for the life of me: I've sprayed it with PB blaster, pounded on it from below and yanked on it from the top. Quite frankly I'm plumb out of ideas as to how to get the darn thing out, anyone ever experienced a similar problem? Any ideas on how to get it the heck out? I did think of using a jack but there is no way I can get one in their with the rear diff in the way, at least not that I can see. Your suggestions are welcomed and much appreciated.
Originally Posted by jdsdidit
Gotta ask..................are you sure you released the locking pin?
Originally Posted by mudmaker
hook up a trailer and crank down the landing gear.
Originally Posted by grafekie
Pull the lever then twist it. It'll latch open
make sure the rod is not bent, or out of the keepers on the bottom of the hitch. It sounds like the pin is not quite releasing. I have one in my '79 that requires me to pull the rod and then push the rod back towards the back of the truck instead of rotate it to lock it in the unlocked position. You should be able to crawl under the truck and verify if the pin is releasing far enough. A few good taps with a bar/punch and a hammer should elease the ball if it is unlocked.
I would agree you have something wrong. I have them in a '94, '01 and '04. The one inthe '94 rarely ever gets turned over but when i need to it just takes a couple of taps on the ball and it pulls right up. On my '04 I had a rhino liner sprayed in after the ball was put in and the first time I tried to turn it over after that I had to get a little western with it as some of the line bonded to the ball and seeped inside the holder. They are one of the best ***** I have found for the money.
The dealer said that he had never heard or seen anything like this before - just my luck. In the end the dealer replaced the middle section for a very reasonable rate.
Thanks all for the advice!
