6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Moisture Separator
Old May 31, 2016 | 08:54 AM
dynarider33's Avatar
dynarider33
Moisture Separator
My "Drain Moisture Separator" light came on last week and I pulled over to drain it only nothing came out. It has worked in the past but dry as a bone now. Anyone else ever have problems with the moisture drain?
Old May 31, 2016 | 09:51 AM
ginomachino's Avatar
ginomachino
i had to rebuild mine. the valve gets clogged and requires cleaning. not sure if thats what is happening to yours but that's what i had to do to mine...
Old May 31, 2016 | 11:42 AM
Herb Brooks's Avatar
Herb Brooks
What he said. But I will say don't neglect it. These fuel systems can be finicky and EXPENSIVE to repair.
Old May 31, 2016 | 12:06 PM
bubba.whit6.4's Avatar
bubba.whit6.4
Mine did that on a 900 mile trip I took last year. It would happen every couple of hours and every time I tried to drain it nothin would come out. I called my ford tech and they told me to clean out my sensor with electrical cleaner. Works like a charm now.
Old Jun 1, 2016 | 07:26 AM
dynarider33
Thanks, can the drain valve be removed from the filter assembly or does it all come out together?
Old Jun 1, 2016 | 07:27 AM
dynarider33
Where is the sensor plug? I'm sure I can find it but it helps to have an idea first.
Old Jun 1, 2016 | 07:41 AM
bubba.whit6.4
Laying under the truck look up above the separator and towards the engine side of it. It's only about 6 inches away.
Old Jun 9, 2016 | 08:47 AM
fatboytx's Avatar
fatboytx
If you search for this problem there are several write ups, with pictures, about how to remove the cover from the water separator, clean it out and replace the sensor. I bought my truck used and had this problem shortly after I got it. I think it took me about 20 minutes but I have a 2WD truck and I don't know how tight it might be in the area with a 4WD truck. I also shocked the fuel tank, after cleaning the separator, to be sure I didn't have a microbe contamination. And I always change my fuel filters with every other oil change. I honestly think it was due to previous owner not bothering to change the fuel filter in the lift pump often enough. Lazy.
Old Jun 9, 2016 | 06:15 PM
CrazySob's Avatar
CrazySob
Make a habit of draining it every 2-4 weeks. I drain mine every other Monday.
If you bought a used truck that had a plugged hfcm drain that's a very good sign that the previous owner neglected it. Checking to make sure clean fuel flows freely from the hfcm is one of the first things you should check for when buying a used 6.4.
With the limited capacity of the water separator you also don't want to wait for that light to come on... Usually once that light pops up water has already found its way into the hpfp and injectors.
Old Jun 16, 2016 | 07:21 AM
ginomachino
When i bought my truck, the valve was clogged. I was concerned. Cleaned it. Been draining it every other tank and no water ever comes out. What does that mean?
Old Jun 16, 2016 | 07:29 PM
CampSpringsJohn's Avatar
CampSpringsJohn
It means you likely have good source for diesel!
I have almost never had any water come out of the drain valve. But the last time I changed the filter, there was a lot of water in the filter.
Raleigh234
May 26, 2016 06:03 PM
davbeisner
Aug 5, 2012 01:11 PM
jasonmilford
19
May 27, 2012 06:24 PM
deadbug
16
Mar 11, 2009 05:51 PM
