Anybody have a pic of removable cross member on a chassis for an automatic trans, which on removal enables the transmission to be removed rearward, leaving the engine in place. The member between the strut bush brackets. Not the rear one that holds the trans mount. Thankyou. Rory.
Thankyou. Jowilker. trans bell will not fit between cross member and cab floor. Heard talk U.S. auto trans frames had a removable crossmember. The member between the I beam strut brackets. Either C6 or C4.
Look at this upper (lower) frame pic for 6A023 which is the rear engine support bracket (that some peeps call a cross member).
On 1965/ F100/250 2WD's with A/T & M/T and ditto 1966/ F100 4WD's, this bracket bolts on.
Lower (lower) pic of engine/trans mounts shows a close up of 6A023
when the OP mentioned bellhousing, I assumed the item labeled 5025. This is the "crossmember" that's I mention in my response. I had to grind off the rivets and replace with bolts in order to get my C6 in and out.
OK, I was speaking of the rear cross member. You have a truck that was a manual shift from the factory. I had the same issue, the rivets have to come out and replaced with bolts so the crossmember can be removed for tranny movement.
5025 part number crossmember is the part in question. Thank you for the response. Rather than disturb the riveted strut brackets I intend to remove a sufficiently wide section of the crossmember to enable trans removal. I will adapt and bolt in removed crossmember section to make it readily removable. Anybody foresee a problem with this idea? All advise and criticism considered. Thankyou, Rory.
Removing the rivets and replacing them with Grade 8 bolts is probably easier and will keep everything structurally equivalent. The radius arm mounts will not move because you don't need to remove the rivets that hold the mounts to the frame rails.
I have some recent experience with this on my truck. The two pictures show two ways to do it. The first is to cut the rivets and replace them with bolts. If you do it this way to remove it you have to remove the cross member at the trans mount also. The second way is to make it two piece. Which has advantages if you want to just remove the pan without a lot of disassembly, because it will come out without removing the cross member at the trans mount. I left mine one piece and just keeping my fingers crossed that I don't have to remove the pan for any reason.
Crop duster. Thank you. I intend to make two cuts and remove all of the horizontal part of the crossmember. Weld joining piece, as you have done, at each end and bolt to crossmember stubs. Maybe with a crossmember from another frame, cut longer to overlap cutout and positioned on top of and bolt to original crossmember stubs. Did factory finally wake up and make later frames with removable crossmember to ease trans removal? Thank you all for your replies.
It's a piece of cake to grind those studs off the top of that 5025 crossmember with the cab off, a whole other thing with the cab on there. Not much room. By the time I was done I wished I had lifted the cab enough to get the damn tranny out and back in.
