400m build questions.
Old May 30, 2016 | 07:22 PM
Crash F250's Avatar
Crash F250
I'm at a stage right now that I'm getting ready to pull my motor out of truck for a rebuild. It is a 400m small block married to a 3 speed auto. I have talked to a few local shops and so far best price is $1,500 to rebuild from top to bottom. I guess what I am wondering is can I rebuild it myself for less? I am also looking to get a little more power out of it. Now with that said I am not looking to build a track monster but would like to think I could get close to 500 to the crank out of it. I am on a budget but still want to get the most bang for my buck. And before any of you guys who are the nay-sayers, yes I have heard it all, ditch the 400 get a 460 blah blah blah, trust me if i had the money I would but I am also trying to keep truck as original as possible. So please keep it to helpful input as much as possible. The truck is a 1977 Supercab Short box F-250 2wd on a posi rear end with about 163,xxx miles. Thank you in advance for any advice and input i receive.
Old May 30, 2016 | 07:38 PM
mikeo0o0o0's Avatar
mikeo0o0o0
To be honest, I doubt you could do it for less than $1500. And I would be suspect of the $1500 quote too. This, of course depends on what kind of shape your engine is in to begin with, how much machine work is needed.
I rebuilt my 390 and had $1100 just in machine work.
There's nothing wrong with the 400, it's a decent engine, it's just engine rebuilding can be expensive, especially when you're shooting for 500 HP at the flywheel.
Just my 2¢.
Old May 30, 2016 | 07:41 PM
F5 DEEG's Avatar
F5 DEEG
What do you motor building skills look like? A while back I saw a budget build on a 351m or a 400 (no m on the 400). I had my 351m sent to tim meyers a year and change ago and to get 500+ ponies it cost me well over the $1500 youve been quoted. on the dyno mine hit 515 hp and 525 tq and it was the exact opposite of a budget build. Tim will send you a build sheet of some of the options he has as a kit that you can purchase. Then you can take the sheet to one of your builds and see what they can do for you.
I would guess the prices you have gotten are for a stock rebuild with minimal new parts. new performance heads and a cam will cost you close to $1300-1500 alone. If you are dead set on getting the 500 HP out of a motor I would suggest looking into a crate motor that will bolt up to your bellhousing and get some matching motor mounts.
Old May 30, 2016 | 08:07 PM
Crash F250's Avatar
Crash F250
I should rephrase my original statement. It would be 1500 for stock rebuild and they would install and aftermarket parts I bring at no extra charge. My engine building skills are a beginner's level but I have a lot of experienced friends willing to help. I guess the main question is would it be smarter to have shop do a stock rebuild and add power upgrades on top or rebuild engine myself and add one desired parts as I go. I know 500hp is a stretch but it's a dream lol. I guess even 400 would be more reasonable.
Old May 30, 2016 | 08:11 PM
PA74F250's Avatar
PA74F250
I think you better shoot for 300hp with your budget and stick to relatively stock. Do the typical mods and you'll probably be much happier than you are now.
Old May 30, 2016 | 08:53 PM
jj79350's Avatar
jj79350
Hey Crash, like you I have the 400 and everyone keeps telling me to find a 460. I kinda want to keep the original motor and have done a lot of searching on ways to improve them. I wish I could afford for Tim to build mine but that will be unlikely. Here are a couple of articles on getting horsepower and torque on a budget. With the help it sounds like you have just have your machine work done and you and your friends can build it with the appropriate parts. After reading the articles I'm sure you would agree that 1500.00 on a stock rebuild would include wasted money on parts you want to change to get that 400 hp. Search ford 351M/400 build and I'm sure you will find even more useful and interesting articles. Good luck
Ford 406 Engine Build - Hot Rod Magazine
351M/400 Performance Build Up
Old May 31, 2016 | 07:03 AM
somethingclever's Avatar
somethingclever
I agree with Mike.
I have $2k in machine work alone for a performance iron-head build....at $1500 stock rebuild I think you better double check what they are quoting you.
Old May 31, 2016 | 02:52 PM
mark a.'s Avatar
mark a.
Your not going to get much of a "rebuild" for $1500. Did they say what that gets you ? Everything will need cleaned. The block alone probably needs align honed, decked, bored, crank turned. Then rods need reconditioned with new bolts, new pistons and balanced. Who knows what all the heads might need ? New valves, maybe some valve seats, guides, milled, rockers could be worn out. Cam shaft and lifters, valve springs, retainers, keepers. Then you would need all the other parts that don't come in a kit. Then assembly + things I'm not thinking of now, water pump, fuel pump, etc. If they do it right and they are good at doing it, they are going in the hole. So the price is more than suspicious I'd say. You get what you pay for.
Old May 31, 2016 | 06:53 PM
Crash F250's Avatar
Crash F250
Thanks for input and info guys. Much appreciated. Ill crunch some numbers and see if I can get off cheaper rebuilding and havin a shop do machine work. I already initially planned on putting new parts on so I might as well do it all as I get money for parts instead of breaking bank all at once.
Old Jun 1, 2016 | 12:03 AM
kegger66's Avatar
kegger66
I ran across these guys that might be worth a look. Ford Performance Crate Engines
Old Jun 1, 2016 | 01:12 PM
palmrose2's Avatar
palmrose2
Cam, lifters, and springs. $175
Gaskets and plastigage. 75$
6" egg shaped burr. 28$
Rod and main bearings. 75$
Weiand intake manifold. 220$
600 CFM Holley. 0$ but would have been 320$
Double true roller timing set 50$
Exhaust components (some stainless) 180$
Correct thermostat. 6$
Adjustable timing kit and timing tape. 43$
Paint. 20$
Anti freeze 25$
Total $1,257.00
Just parts, and you don't see pistons or valves in that list. You can NOT get horsepower without aftermarket cam, intake manifold, and carb. Real horsepower costs real money, and unless you can find a free carb and intake, you are down $600 right out the gate.
Old Jun 1, 2016 | 05:32 PM
Crash F250's Avatar
Crash F250
Awesome thank you. After speaking with my wife I think I have convinced her to let me go beyond just a stock rebuild so once I get this last bill paid off here soon I may look into getting the motor work done one way or another.
Old Jun 1, 2016 | 07:59 PM
tabascom16's Avatar
tabascom16
You will not see 500hp without some high flowing aftermarket heads and a rather radical cam. With a radical cam you need high compression as well to take the benefit of it as well. The cam simply moves the torque curve higher up in the RPM band which makes the engine VERY sluggish down low. Cars make up for that by having very small diameter tires and numerically high gear to keep the RPMs up.
Horsepower is simply torque times the RPM it was measured at divided by 5250. At 5250 rpm torque and HP are the same.
That being said I have a 408W stroker with 9.6ish compression, AFR 185 aluminum heads and an Extreme Energy 218/224 duration at 50 thousands cam. Good cam for a truck or SUV. This engine combo makes about 500ft-lb torque and peak HP of 380-400 at the crank. To get 500hp, bigger heads and a much bigger cam is needed. Even with good high flowing heads and a radical cam most 408W strokers can get to 525-550hp. After that it gets very costly for marginal gains and start talking race gas.
Old Jun 1, 2016 | 08:03 PM
Crash F250's Avatar
Crash F250
Agreed i know that to get big numbers I would have to drop big money. That's why in one of my last posts I mentioned that I know it will be highly unlikely I every see 500 but upper 300's would be nice none the less. If I can get it anywhere near 400 or just over I'll be happy.
Crash F250
Aug 30, 2016 06:47 PM
shorty2tall
May 15, 2012 09:54 PM
detmerdj
Jul 25, 2005 06:11 PM
HighRollin
S. California Chapter
Oct 17, 2004 09:22 PM
fndoffrddign
20
May 31, 2000 09:26 PM
