Let's get destructive
Old May 30, 2016 | 04:38 PM
BTFordGuy302's Avatar
BTFordGuy302
Keep the hoist lifting it up even over night. Also a little heat and keep spraying it when lifting.
Had a buddy that could not remove heads from a 312 powered Tbird used the hoist on the heads and left it that way over night. came in next morning and they were lose.
Dave ----
Ok cool guess that's the route I'll
Take, and hope, yeah right now my tires are even off the ground
Old May 30, 2016 | 07:46 PM
reamer's Avatar
reamer
heat the block to cherry red, that was to only way the dizzy came out of my 460,
That was after I snapped off the base from the shaft with 2 pry bars and a week of pb-blaster.
Heat up, cool down, hand removal after that......
Old May 31, 2016 | 11:24 AM
BTFordGuy302
Thanks reamer I'll give it a try if it hasn't come loose over night, it's at my parents house since I live in the city and working on your car on the street is frowned upon I guess lol hopefully I can get up there after work and we'll go from there!
Old May 31, 2016 | 06:28 PM
dnkensinger's Avatar
dnkensinger
I Had this happen on a 302 before that we were building for a mustang. The distributor shaft was slightly larger than the opening in the block recessed in the block. After much sweating and cursing, it finally hit me- drop the oil pan and get it from underneath. The engine was in the car when we did this and it worked great - we went to home depot and got some steel round stock just slightly smaller than the distributor shaft and used it as a drift pin. My advice would be to use a small sledge hammer so you can get some good power behind the hammer blows. It took about a dozen hits and the thing popped right out. Hope this helps.
BTW, was this engine running before you started this project and is it the factory distributor? I've heard of OE distributors getting stuck but not as bad as you describe. Of course, there's always a first for everything. Just like when edelbrock told me when I called them about a float that failed and filled up with gas - "Oh, we've never had that happen". Yeah, well I must be lying then!
Old May 31, 2016 | 07:00 PM
kr98664's Avatar
kr98664
And here's the simple process for gaining access on a pickup to drop the small block oil pan (chuckle, guffaw, snorting coffee out my nose...)
https://www.ford-trucks.com/forums/1...y-84-351w.html
Old May 31, 2016 | 07:21 PM
dnkensinger
I hear ya man, never said it would be easy.
I should also mention that this 302 had the double sump pan with the cross member running directly underneath it. Had to do the same thing - remove engine mounts and lift the engine about 4-5 inches and stick 2x4's between the block and frame.
It was still quicker than pulling the motor though and what else are you going to do if the distributor is stuck that bad?
For the record, I've done 3 of these types of oil-pan gaskets and I LOATH, LOATH, LOATH the job. What a crappy design!
That guy in the link you referenced had a hilarious opening statement LOL
Old May 31, 2016 | 08:11 PM
BTFordGuy302
Hey guys! Great news I got it out! You'll never guess what I used! Dubs, it's an aluminum alloy cleaner that smells like crap but works wonders! Combined that with a few taps of the hammer, a pipe wrench and a well placed crow bar! Thanks for the help guys!
Old Jun 1, 2016 | 04:57 PM
mountain dewd's Avatar
mountain dewd
Congrats man! Now tell me, what are ya goin to do with it?
Old Jun 2, 2016 | 05:16 AM
BTFordGuy302
I gave it to my mom for her metal arts and crafts stuff. She makes stuff out of horse shoes and scrap metal. I was tired of looking at it haha
AbandonedBronco
Jan 19, 2012 02:27 PM
704 dentside man
Jun 9, 2010 05:23 PM
FourWheel
Mar 2, 2008 06:32 PM
eandaauto
Jun 1, 2004 11:17 PM
jkorreck
Aerostar
May 19, 2004 04:19 PM
