Let's get destructive
Old May 30, 2016 | 02:28 PM
BTFordGuy302's Avatar
BTFordGuy302
Hey guys, sorry I havnt been around much lately new job, new house and now truck problems... So I just picked up a nice 351 Windsor engine and got it in my truck, but I'm trying to get the old ugly distributor out. It's jammed up pretty good and I'm on day 3 of spraying it with pb blaster and wd, torching it, hammering it, etc. and it still won't budge. Any suggestions on the most fun way to get this out while destroying the distributor in the process? I have no plans on reusing it and it's broken already anyway. Yes I removed the distributor hold down bolt lol
Old May 30, 2016 | 02:43 PM
mountain dewd's Avatar
mountain dewd
You can destroy it all you want, but life's no fun when you break the top off and leave the bottom broken off flush to the block.
Get it out by any means necessary, then overkill it after it is out of the motor (shoot it, melt it, blow it up, throw it into a volcano etc).
Old May 30, 2016 | 02:45 PM
BTFordGuy302
Just an update, I currently have my truck dangling from an engine hoist by the distributor to give y'all an idea of how stuck it really is...
Old May 30, 2016 | 02:46 PM
BTFordGuy302
Lol I will probably do all of the above! Any ideas of how to get it out?
Old May 30, 2016 | 02:52 PM
mountain dewd
That's what I like to hear! Will the distributor rotate any? Maybe start trying to rotate it left and right?
Old May 30, 2016 | 02:59 PM
BTFordGuy302
Nah not at all, I even tried turning it with vice grips and a pipe wrench with a cheater bar
Old May 30, 2016 | 03:01 PM
mountain dewd
Jeez. I haven't ever had a seized dizzy before. Does the engine run with it?
Rusty_S's Avatar
Rusty_S
What about a chisel angled between the dist and the block itself? I did that on a chevy and gouged the aluminum manifold but hitting it with a hammer like this jarred it as well as causing it to pop up letting it loose.
Old May 30, 2016 | 03:03 PM
Rusty_S's Avatar
Rusty_S
Ive seen them run with stuck distributors that would not turn nor come out. It really sucks though. I am praying when it comes time to do that to my '56 that my dist comes out without being stuck. Thankfully I can pull the intake off which will be anyways to swap the original 4v one back on but I can have more room at getting to the dist in the back to get it broke loose if it is seized in place.
Ive seen using angled prybars even to get under the dist to pry up on them to get them free.
One trick is if the dist is shot anyways use a chisel and try to get the dist to rotate. Once it spins a bit it will come out then.
Old May 30, 2016 | 03:04 PM
BTFordGuy302
Nah, i wish lol I woulda given up and just kept using it haha
Old May 30, 2016 | 03:06 PM
BTFordGuy302
I'll try the chisel method, I was using a chisel any way to put a groove in it and then use the groove to try and turn it but I just kept chiseling away at the base lol
Old May 30, 2016 | 03:15 PM
kr98664's Avatar
kr98664
Snap-On used to make a slide hammer attachment (#CJ99) for pulling stuck distributors. Used ones turn up on eBay. More details in this thread:
https://www.ford-trucks.com/forums/1...zzy-stuck.html
Old May 30, 2016 | 03:22 PM
BTFordGuy302
Unfortunately I tried hitting up on the bottom of the part of the distributor that this goes under and it pretty much separated from the shaft....
Old May 30, 2016 | 03:23 PM
BTFordGuy302
Chisel didn't work... I can't get a deep enough groove to get a pry bar under...
Old May 30, 2016 | 04:35 PM
FuzzFace2's Avatar
FuzzFace2
Keep the hoist lifting it up even over night. Also a little heat and keep spraying it when lifting.
Had a buddy that could not remove heads from a 312 powered Tbird used the hoist on the heads and left it that way over night. came in next morning and they were lose.
Dave ----
