pushrods? ASAP
Old May 11, 2007 | 02:00 PM
highboy390fe's Avatar
highboy390fe
Exclamation pushrods? ASAP
I am building a 390 bored 30over running d2te heads with cj valves and a 941 cam, "s" code intake and 750 holley, I am needing to order pushrods and need to know what length or from what year to get I need that asap so help as soon as you possily can please. Thanks Guys
Old May 11, 2007 | 03:06 PM
Bear 45/70's Avatar
Bear 45/70
Ther are only 2 types of standard FE push rods. Push rods for adjustable rockers are all the same length. The non-adjustable push rods have 3 lengths, standard, .060" longer and .060" shorter. Unless you've gone wild on decking the block and shaving the heads the standards will usually work.
Old May 11, 2007 | 03:23 PM
highboy390fe
thats what i wanted to hear thanks
Old May 12, 2007 | 11:02 PM
seetwisted's Avatar
seetwisted
After you put it together it won't hurt to check the pre-load...don't take it for granted that it's all right
Old May 14, 2007 | 12:35 PM
highboy390fe
ok i will do that. thanks for the tip
