65mm BBK 6.8 TB - Anyone have one dialed in?
Still trying to get this TB dialed in, I have the idle screw to a point that truck idles at 830 which is ok. The thing I need help with is sticking gas pedal at a full stop, I guess vacuum causes the issue and the idle screw is supposed to adjust to where it stops? Only problem it won't stop no matter where I put the idle screw. Any help from guys that have it running perfect I'd love to hear it.
One other thing when I'm going at a decent speed and let off the gas the truck pretty much stays at the same speed instead of slowing down, I bent the throttle return spring and the spring tension is not closing it all the way over 35mph Need to find a spring if anyone has one, Ford sells it as a complete unit only.
Have a great Memorial day guys
The idle is actually fine, the sticking gas pedal is my biggest problem. The Part bbk 7110 is made for a couple engines 5.4 and 6.8 and says on bbks tech service board that this is a known issue:
BBK : Installation Instructions
It addresses the problem 3 paragraphs down, pretty much says to turn the idle screw towards the linkage a couple turns in which the plates won't close all the way at full stop, but I've been messing around with it for over a month and stills sticks.
Also I replaced the IAC when we installed this as well.
When I first installed it the pedal would completely stick and I'd have to nail the gas pedal for the tb to open. I didn't know what it was and I bent the throttle return spring (stretched it by pulling bothsides) somehow thinking that would let the tb open.
Besides all that I think it may be the part.
TheV8tractor
03-23-2015 04:29 PM
voodoosurfer
07-12-2004 12:56 PM
