EFI Idle adjustment procedure?
Old Jan 18, 2004 | 11:59 PM
sdnorden's Avatar
sdnorden
Does anyone know the procedure to adjust the idle speed on a 95 F150 with the 300 CID engine? More specifically the idle stop screw located on the throttle body? The little sticker says not to adjust the screw, but ours had been adjusted during trouble shooting a high idle problem. Now that is fixed we need to reset to factory spec.
I am assuming the screw sets base idle and needs to be performed without the idle air control valve affecting idle speed. I am also assuming that the idle stop screw keeps the throttle plates from fully seating in the bore, not sure what may happen if they do fully seat.
Thanks,
Old Jan 19, 2004 | 07:23 PM
rhetor's Avatar
rhetor
The computer will get the idle down right for you, as long as that rest screw isn't really out of line.
That's really so there isn't any lag in the pedal. Just adjust it so that the throttle still sits on it. If it helps, mine is about half n half in there.
thedopefishlives
Mar 17, 2017 05:31 PM
sandymane
Feb 18, 2017 09:01 AM
sandymane
20
Nov 13, 2016 07:41 PM
1986F150six
Nov 1, 2016 01:48 PM
japple157
Nov 20, 2015 01:18 PM
