Sponsored by: Auxito
Engine turns over but will not start
Old May 28, 2016 | 01:05 PM
bluecobra's Avatar
bluecobra
2001 F-150 5.4 extended cab
You have probably seen this before. Engine cranks but will not start. Backed into driveway, loaded recyclables, truck would not start. Fuel pump relay clicks, a small amount of gas comes out of the schrader valve on the fuel rail when I press the stem with a phillips head sd. When the engine is cranking the check engine light is on so I assume the computer is working but there are no RPMs showing on the tach. At this point I'm thinking a bad crank position sensor. Would that sucker go all at once like that? I believe they hid that behind the ac compressor. Am I looking at removing the belt and compressor to get at the sensor? Any help/advice is appreciated.
Old May 28, 2016 | 02:05 PM
brokenleg's Avatar
brokenleg
put a gauge on it for the fuel pump
Old May 28, 2016 | 06:53 PM
projectSHO89's Avatar
projectSHO89
"A small amount of fuel" suggests a fuel supply problem. You should have 40+ PSI which should spray out vigorously after a fuel pump priming cycle.
Brokenlegs is correct. Get a fuel pressure gauge and MEASURE your fuel pressure. That's the difference between knowing and guessing.
Old May 29, 2016 | 10:00 PM
steve(ill)'s Avatar
steve(ill)
when you turn the key "ON", but don't crank, the THEFT light comes on for 3 seconds, then goes out when the computer recognizes the KEY as matched to the truck... Your light goes out after 3 seconds ?
You should get a "small" amount of fuel when you push the Schrader valve, but it should have 40 psi behind it so it will spray.
Dstosh
Jan 14, 2022 01:29 PM
parcher440
Oct 5, 2016 12:32 AM
Brown Bear
1997 - 2003 F150
Nov 18, 2012 05:47 PM
dirtmonkey11
Feb 26, 2010 10:14 AM
kwade66
Jun 3, 2006 04:06 AM
