Rear highboy spring pad with
Old May 27, 2016 | 04:12 PM
SuperDuty93's Avatar
SuperDuty93
Ok guys ive searched and searched and can not figure out what the rear spring pad with center of pin to center of pin it. I have new pads ready to go on my 14 bolt axle and don't want to weld them into the wrong spot . Anyone know?
Old May 27, 2016 | 10:44 PM
lafermedavid's Avatar
lafermedavid
hb spring perches
Im coming up with 39.75,Ill measure tomorrow in daylight
Old May 27, 2016 | 11:50 PM
SuperDuty93
Thank you. I got 40 but doing it on my own is kinda hard.
Old May 28, 2016 | 01:12 AM
akguy09's Avatar
akguy09
Your best bet is to locate the axle under the truck set the springs on the pads. Make sure the axle is centered and pinion angle is correct, then tack weld the pads. Remove axle for final welding
Old May 28, 2016 | 09:07 AM
lafermedavid
10/4 I like that ,and clocking it as well ..ok daylight ,,,when I hook my tape to the side of my rear blocks,and measure outside to inside ,I come up with 40.25.When I hold tape center to center,still looks like 40.25.Which confirms Ak suggestion of placing axle under the truck,and mocking up the saddles.good ? will help others down the road
Old May 28, 2016 | 11:40 AM
SuperDuty93
Yup agreed. Was hoping someone already did it so I csn have the axle ready to go in before I pull my old rear :P
Old May 28, 2016 | 03:39 PM
good to doo's Avatar
good to doo
Wondering what year of 14 bolt your using, is it disc brake?
Old May 28, 2016 | 05:06 PM
SuperDuty93
I belive it got it out of a late 70's chevy 1 ton. 67.5" wheel face to wheel mount face. Slightly wider then the ford dana 60. As close as I could get to the 69.25" wide Dana 60 kingpin front axle.
Old May 28, 2016 | 05:30 PM
good to doo
Ya I was wondering about the width to, cause my truck also has the front dana60 and I really don't like how the front tires stick out further than the backs.
Old May 28, 2016 | 05:35 PM
lafermedavid
corp 14
post some pics as you go along with your project
sammie0126
Aug 7, 2013 09:15 PM
98Stang
Feb 9, 2011 09:06 PM
tgowers
Oct 20, 2006 06:53 PM
oldfords4ever
Mar 15, 2005 12:47 PM
