are there any axles that swap easily into a highboy?
I blew up my dana 60 rear axle really bad. I've priced out a new gear set, limited slip and bearing set and its pretty spendy. so i have been looking locally for a used rearend. turns out highboy rear axles are hard to find around here. are there any other years, or rear axles that swap under these trucks easily? are there any large salvage yards out there that would ship one to me? (for a decent price!!) thanks
personally I'd put a corporate 14 bolt in it. That's what I plan to do with mine. It's MUCH cheaper to buy and to upgrade than the d60(lockers are half the cost). If you don't mind having a GM rear end. As far a rear axle goes you can use virtually any axle pretty easily. You may or may not have to move the spring pad but thats easy. If you want to stick with a Ford product I would go Sterling 10.25 or 10.50. Parts a little more $$. JMO
I second the 14B. Unless you are a "must have Ford parts" guy the 14B is a great replacement to the D60. There is lots of info on the web about them; they are dirt cheap and easier to work on.
The distance between the spring pads is the main issue when concerning a direct swap. That, and the highboys use a narrower spring pack, and the pad on the axle is correspondingly narrow. I know some dually chassis cab fords used the narrow spring pack and pad well into the 80's. If you don't have the ability to relocate the spring pads on the axle housing, then you'll be stuck looking in the junkyard with a tape measure to find something close. You can always modify a wider spring pad if the center to center distance is close. The 14 bolt is a good axle, but I'm more fond of the sterling. That's what is in my highboy, albeit with a little modification.
-Jared
-Jared
Why do you prefer the Sterling? I'm considering both. What mods do you have to do for the sterling? just spring pad position?
The Sterling is a good bit stronger than a 70 as well. The axle shafts are the same size, but the pinion on the 70 is tiny.
-Jared
Good info. They may be the same price at the yard but a locker is like $165-200 more for the Sterling. I do like keeping everything Ford and like running the underappreciated stuff, but the purpose for the swap would be to upgrade strength while lowering cost of parts. The Sterling parts are even more expensive than the D60. I'll keep my eyes out for a deal on one on craigslist though. If I could find a Sterling with locker for the right price, I'd take it. Otherwise probly going with the 14bt.
countrydriven
12-04-2016 02:13 AM
abosely
03-27-2016 05:37 PM
Dave2488
20
05-29-2012 06:28 AM
Fordman7780
13
09-18-2002 09:14 AM
