Another starter question
Old May 26, 2016 | 12:14 PM
hrhankypoo's Avatar
hrhankypoo
Did some searching and can't find an answer anywhere. I have 460/c6 in my 1979 bronco and everyone says to put a starter off a newer 460 on it. I bought one for a 1995 f350 with an auto but the gear has 10 teeth but my old one has 9. Will this work or did I get the wrong one? Thanks in advance.
Old May 27, 2016 | 12:51 PM
cbakker's Avatar
cbakker
Check the gear size if they are the same diameter, then obviously it won't work. I always check I f the gears on the old one mesh with the gears on the new. I haven't seen a thread about that for a while, but I know it was common to make the switch to a mini. I will try to find one.
Old May 27, 2016 | 01:07 PM
cbakker's Avatar
cbakker
Check these out:
https://www.ford-trucks.com/forums/7...-76-460-a.html
https://www.ford-trucks.com/forums/1...-any-good.html
Old May 27, 2016 | 06:15 PM
hrhankypoo's Avatar
hrhankypoo
Thanks for the links! Guess I wasn't searching the right words. I appreciate it.
Kyle Wood
Aug 4, 2018 05:00 AM
hrhankypoo
1978 - 1996 Big Bronco
May 26, 2016 09:37 PM
wotan
Jul 29, 2013 02:19 PM
Blake Phipps
43
Jul 25, 2013 07:23 AM
tastyklair
Aug 24, 2006 04:26 PM
