Mini high torque starter
Old Jul 23, 2018 | 06:08 PM
Kyle Wood's Avatar
Kyle Wood
Hey guys, another question...
so i got a rebuilt high torque mini starter that came out of a 351w. I was wondering if this will work with my 400? I saw on my current OE starter it has a 10tooth starter gear, however, my high torque starter has a smaller but bigger tooth 9 tooth starter gear.
im hoping this works for my truck, if not how hard is it to swap that gear to the correct one?
Old Jul 23, 2018 | 08:20 PM
hivoltj's Avatar
hivoltj
No, 351m, 400 and 429/460 share starters. A '96 f-350 starter for 460 is a factory gear reduction. I got one from rockauto for my '77 for like $62.
Old Jul 30, 2018 | 07:06 PM
lafermedavid's Avatar
lafermedavid
hivolt did you have to do any shimming if you can remember on your 460 starter,I just bought one
Old Jul 30, 2018 | 08:40 PM
PA74F250's Avatar
PA74F250
I did not shim my newer pmgr starter on my 460.
Old Aug 3, 2018 | 12:37 PM
hivoltj's Avatar
hivoltj
NO! Ford starters that bolt to the bellhousing do not use shims. That is a GM thing.
Old Aug 4, 2018 | 05:00 AM
1TonBasecamp's Avatar
1TonBasecamp
Not any longer apparently. Not only does Dorman have Ford starter shims on it's "HELP" racks now (for about the last ten years or so as far as when I first noticed) but more and more people are having to shim theirs.
Might be all the odd swaps being done, or it might be the sad state of affairs with the quality of the parts we get these days. So far I've never had to shim one, and none of my close friends have either. But I've had several customers and talked to forum members that have needed something because their (correct) starters did not work without a shim.
I realize this is a 400/460 discussion, and the shims are for the Windsor family, but it's a thing now so I thought I'd throw it out there.
Paul
68murc
Dec 20, 2014 08:53 PM
crushtheogre
Sep 2, 2014 03:31 PM
TheThickster
Feb 17, 2011 05:55 AM
Colo79Ford
Nov 28, 2009 01:12 PM
gray79f250
Jun 20, 2002 08:53 AM
