I am stranded in AR and trying to get to GA. My ac compressor just took a crap. new serpintine belt I just installed today is loose. Is there any way to bypass the ac compressor and just get a smaller serpintine belt just so I can drive the truck?? 97 F350 Dually Diesel. Please help!!
As long as your turning the water pump, how is the motor going to burn up?? I'm not sure that a belt off of a non-ac motor would be the right fit but it would be a place to start, size wise. Turning the air pump is a necessary thing unless your very strong for the steering and the brakes.
Can't you just throw on a new clutch assembly and get home? It's a lot cheaper than a new compressor. It won't hurt anything. Most mechanics these days don't have a clue how to replace the clutch probably though.
the autozone link above is a ac bypass pully for 39 bucks. bolts in place of compressor
I don't think that'd be a good idea unless you want to permanently dump the A/C. The compressor is probably fine and if you remove it you'd have to get the A/C recharged.
My uncle who is a retired mechanic said to have the bearing replaced and that should fix it. Im gonna see if that can be done quickly. otherwise I am going with the by-pass. Thanks
its a cheap fix to get home. he said the compressor was locked, so it needs to be recharged any way.
There is a bearing for the pulley that is outside the refrigerant space. Just because the pulley is lose and it shed metal doesn't mean the compressor itself is bad.
